> Main Targa Seal Install, A/K/A Defeated by rubber
johnlush
post Mar 28 2019, 05:56 PM
What's all this then?
After way too many hours on this I'm out of ideas. Yes, I've searched and it looks like struggling with the installation of the main targa seal is part of the game but it is possible. That has not been my experience. I got the right a-pillar portion installed by sliding it down from the top although everything I've read said that wouldn't work and to seat the inside lip in the channel and work the outer lip into the trim with a suitable tool. So far so good and off to the left side. Nothing and I mean nothing works. Tried sliding from the top and it binds about a third of the way in and will go no further. I've already examined the track for dings and crud and it's clean and mostly straight. So I give up on that idea and decide OK, let's do the one lip at a time thing. I can't get it to start using anything I try. I have flat nylon tools, screwdrivers, putty knives, you name. it.
I've heard it alluded to that there are pictures and/or videos of how the #%^& to do this but I can't find them.
Any words of wisdom would be greatly appreciated...
Replies(1 - 19)
mgphoto
post Mar 28 2019, 06:16 PM
"If there is a mistake it will find me"
Sex lube, water soluble.
ie: Astro Glide
JeffBowlsby
post Mar 28 2019, 06:21 PM
Glycerin is your friend. Careful to not tear the corners.
johnlush
post Mar 28 2019, 07:35 PM
I tried silicone paste - is water-based stuff any better? And using which method? Slide it in from the top or work it in one lip at a time? (IMG:style_emoticons/default/blink.gif)
This thread sounds a lot dirtier than it really is... (IMG:style_emoticons/default/biggrin.gif)
Chi-town
post Mar 28 2019, 08:40 PM
Most silicone paste have petroleum additives which will cause rubber to swell. Try 3M Dry Silicone spray and don't be bashful with it
tomh
post Mar 28 2019, 10:37 PM
I was able to do it by pushing slowly and steadily with the help of Joy soap.
Mblizzard
post Mar 29 2019, 06:20 AM
I added heat from a hair drier to make it a bit more flexible. Don't use heat gun. It is too easy to get it too hot and tear. Takes longer to get warm but those things are expensive too mess up.
rhodyguy
post Mar 29 2019, 07:17 AM
Buy the big container of glycerin at Riteaid. It doesn't go bad. 'Paint' both the rubber part and surface the item will be place upon. Bring the seal into a warm room before installing.
dr914@autoatlanta.com
post Mar 29 2019, 08:42 AM
it needs to fit tightly to seal, silicone grease by Wurth, first straighten out the factory pinches in the two windshield frame gutters, then line up the horizontal blocks to align with the two top side seals, then cinch onto the ledge with a soft rubber hammer, make sure that it is aligned carefully and do not cut!
Mikey914
post Mar 29 2019, 08:49 AM
The rubber man
We do it a little differently. You can install the corner block in with the back edge in the inside track. Push about 1" into the back side an then (carefully) push the front lip of the vertical into it's track. Continue to work you way down pushing the back edge in then the front. It takes a little time, but is WAY easier than trying to pull it through.
Repeat on the opposite side then push the upper section onto the top of the windshield area.
Yes it's a pain, but corners, sides, top.
(IMG:style_emoticons/default/beer3.gif)
Then Beer
johnlush
post Mar 30 2019, 05:10 PM
Thought I'd update this. It's in. I ended up using the "Mikey Method" on the left hand vertical piece. I was able to slide in the right side with a lot of pushing, pulling and coaxing but the left side would invariably bind about a third of the way in. Given the choice I prefer the slide it in method as it seems less likely do damage the new seal.
I'm assuming I need to trim the vertical legs to match the rubber wing window blocks? Utility knife?
Things I learned:
• This is not a quick job - at least not for me. I suppose it's like most things, the more you do the easier it gets.
• You will swear and sweat and your fingers will hurt during and afterward.
• You'll be afraid that all of the pulling, pushing, poking, etc. will destroy your new expensive seal.
• Glycerin is not readily available at all drug stores - I went to Walgreens because that's what's here.
• Water-based "personal lubricant" works well and does seem to be easier to find.
• You may have a somewhat awkward conversation with the young pharmacy employee about the relative merits of glycerin versus sex lube. (IMG:style_emoticons/default/lol-2.gif)
• You will probably need a beer break somewhere in the process and another one afterward while you put away the 973 various tools you got out because "that might be just the perfect tool!"
Thanks again for all of the suggestions! (IMG:style_emoticons/default/beerchug.gif)
Mikey914
post Mar 31 2019, 12:58 PM
The rubber man
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) Yes ,
not a super easy job. Looks simplier that it is.
To cut the bottoms. Close the door enough the overrun touches the seal on the door.
Mark with an ink pin.
Then using an extendable utility knife (with break off blades) extend it out 2" or so. Using soapy water to keep the blade lubricated, cut squarely just below the line.
If you keep the blade lubricated you will be surprised how easy the rubber cuts. It will slice through skin also as easy so be careful.
This will make a sea between the door and the pillar tight and help keep water out, and we all need that. (IMG:style_emoticons/default/smilie_pokal.gif)
Also you noted the pulling and prodding. Don't worry all of our seals are fully bonded and ours even have the metal co molded into the rubber.
This was a problem on an earlier version.
RiqueMar
post May 20 2020, 12:03 PM
Enrique Allen Mar
QUOTE(Mikey914 @ Mar 31 2019, 11:58 AM) *
Reviving this thread, as I'm working on this later today. @Mikey914 it seems others are using various lubricants, do you recommend doing the same and if so, which?
bbrock
post May 20 2020, 12:14 PM
Just my 2 cents - Porsche recommended glycerine for general maintenance of the natural rubber seals to keep them soft and supple so that is what I use. I'm not saying something better hasn't come along in the last 50 years or that glycerine will work to "nourish" whatever rubber compounds that 914Rubber uses, but I've had no complaints with it.
ValcoOscar
post May 20 2020, 12:26 PM
Garage Life
I saw a recent video where Matt from 914Rubber installed Main Seal on his car.
Now, I can't find it. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/blink.gif)
Oscar
RiqueMar
post May 20 2020, 12:32 PM
Enrique Allen Mar
QUOTE(ValcoOscar @ May 20 2020, 11:26 AM) *
Oscar
That would be incredibly useful. Seems like this part of the project is a pain in the ass, if it doesn't surface and I'm successful with the first side, I volunteer to make a video showing the 914rubber method on the following side.
ValcoOscar
post May 20 2020, 12:33 PM
Garage Life
@RiqueMar
https://www.youtube.com/watch?v=ui-GSfUS7ak
Oscar
RiqueMar
post May 20 2020, 12:41 PM
Enrique Allen Mar
QUOTE(ValcoOscar @ May 20 2020, 11:33 AM) *
They make it look so easy! (IMG:style_emoticons/default/popcorn[1].gif)
cpavlenko
post May 20 2020, 01:16 PM
I'll be doing this seal in a few weeks. I got my front main targa seal from 914 Rubber in 2018. It looks like alot of grunting and patience to install. I'll let you all know how it went when finished.
PCH
post May 20 2020, 02:18 PM
Here's my experience:
I thought I 'd save money and buy an aftermarket seal. Spent all weekend pushing and grunting to get the seal down the channels. Even enlisted neighbors to help with the project.
Turns out someone didn't pay close attention to how the corners were manufactured-they would never fit into the corner tabs.
Ended up paying the big bucks and ordering the genuine German seal. Brought it home, and still in my office attire, I thought I make sure it would fit. As it turned out, I had it installed in 15 minutes! All still in my office attire!
From my measurements, I could now see the dimensions of the aftermarket part were all off. When I returned the aftermarket part I got a store credit for pennies on the dollar.
So, the moral of my tale is this: if it doesn't fit right away it will probably never fit right. I wish I had initially spent the bucks on the genuine Porsche part.
- Lo-Fi Version Time is now: 19th April 2025 - 12:55 PM
