AvalonFal |
Member ![]() ![]() Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region ![]() |
Finally did the shop vac into tail pipe/soapy water thing on my exhaust and came up with leaks at both connections to the muffler. Dropped the muffler and noticed that its flange mating surfaces were pretty flat, but that the header outlet flanges were not. A straight edge rocks about 1/16 - 1/8 of an inch across each flange in the middle between the 2 outlets on each side. Thought the gasket would seal the difference but it apparently doesn't.
So, is this normal or should all the flange surfaces be flat, and is grinding them down the easiest way to level them off?? Or can I put some type of high temp sealer on the flanges?? Paul |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Not normal but certainly no uncommon.
Large flat file well get them flat enough to seal. Jim |
Lo-Fi Version | Time is now: 26th June 2024 - 12:33 PM |
