dt4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England ![]() ![]() |
Hi
Could someone advise if the front screen trim is polished stainless steel or chromed please Mine is scratched and just wondering if is polishable Thanks |
dt4 |
beech4rd |
Member ![]() ![]() Group: Members Posts: 344 Joined: 10-January 07 From: Highwoods, Saugerties, NY Member No.: 7,445 Region Association: North East States ![]() ![]() |
It's an anodized finish. You can polish it. If you do so, you will remove the anodizing and it will tarnish, requiring that you polish it again and again. It does look a lot more shiny when polished, though. The only way to return to the original finish is usually to replace the trim with new. I believe it's still available from your local Porsche dealer. Chris |
dt4 |
thanks Chris, do you know if it comes out separately to the wind screen or does the glass have to come out?
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Chi-town |
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California ![]() |
Clear anodized aluminum
You have to strip the ano before you can polish it |
dt4 |
thanks Chris, do you know if it comes out separately to the wind screen or does the glass have to come out? comes out separately. Buy a trim remover and watch youtube videos on how to remove. i have the trim removal tools, I will track down the how to video, thanks |
dt4 |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Basically you can wet sand and polish it. If you use a 2 stage wax with a polish sealer it will last outside for quite some time. The trick is not to deform it while polishing. A 1000 or1500 grit would be a good start finishing with a 2000.
If you need new I can help out, but looks salvageable. |
dt4 |
Basically you can wet sand and polish it. If you use a 2 stage wax with a polish sealer it will last outside for quite some time. The trick is not to deform it while polishing. A 1000 or1500 grit would be a good start finishing with a 2000. If you need new I can help out, but looks salvageable. That's really useful, thank you. I'll give it a go. I am building a list of the parts I need to order from you so if it goes Pete Tong I can add these to the list |
Lo-Fi Version | Time is now: 26th June 2024 - 09:31 AM |
