case cylinder hold down bolts, removal |
jb57tub |
Sep 16 2019, 08:50 PM
jb57tub Group: Members Posts: 23 Joined: 9-January 19 From: Corpus Christi, Tx Member No.: 22,790 Region Association: Southwest Region |
Should I use a little heat at the case halves to remove the cylinder hold down bolts? The case halves are not being reused. double nutting the bolts for removal. Removal all other studs will be done the same way. Thanks Jon
mepstein |
Sep 16 2019, 08:55 PM
914-6 GT in waiting Group: Members Posts: 19,326 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
We use MAP gas. 2-3 minutes on the aluminum around the stud. Doesn’t hurt the case.
jb57tub |
Sep 17 2019, 10:54 AM
We use MAP gas. 2-3 minutes on the aluminum around the stud. Doesn’t hurt the case. Thank you for the reply. Won't be reusing the case , just wanted a good safe way to extract the studs. Case was ruined by the PO tightening the oil pick-up too tight and breaking the hold down inside the case. Was a good early 1.7 case. Picked up a good 1.8 case here from an earlier add. Jon |
mepstein |
Sep 17 2019, 11:13 AM
We use MAP gas. 2-3 minutes on the aluminum around the stud. Doesn’t hurt the case. Thank you for the reply. Won't be reusing the case , just wanted a good safe way to extract the studs. Case was ruined by the PO tightening the oil pick-up too tight and breaking the hold down inside the case. Was a good early 1.7 case. Picked up a good 1.8 case here from an earlier add. Jon The heat will just make it easier no matter what. I've removed hundreds of studs on 911 engines and rarely break a stud and it's just less physical effort. |
Superhawk996 |
Sep 17 2019, 05:17 PM
914 Guru Group: Members Posts: 5,955 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
The oil strainer pick up bolt is not part of the case itself.
Lo-Fi Version | Time is now: 20th June 2024 - 09:16 AM |
