FI Fuel Pump Pressure Reduction |
rickso71 |
Jun 30 2005, 04:49 AM
Member Group: Members Posts: 74 Joined: 31-October 04 From: Derry, NH Member No.: 3,041 |
My 1.7L has been converted to carb. and not sure if I can just add a pressure reducer after the fuel pump or need a new low pressure pump.
SLITS |
Jun 30 2005, 06:49 AM
The stock pump has a provision for "return to the tank". If you use a pressure regulator with it, get the one that also has a "return to the tank". Mallory makes one as I remember.
Otherwise, just buy a FACET pump and use a pressure regulator inline with no return to the tank. |
ClayPerrine |
Jun 30 2005, 07:01 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Using the FI pump on carbs is a very good way to end up with a barbecued 914.
Buy a facet pump and put it on the car, or put the FI back and use the current pump. |
Lo-Fi Version | Time is now: 26th December 2024 - 08:34 AM |
