jb57tub |
jb57tub ![]() Group: Members Posts: 23 Joined: 9-January 19 From: Corpus Christi, Tx Member No.: 22,790 Region Association: Southwest Region ![]() |
Trying to determine if a T1 oil pump is replacement for the T4. I think they put out a little more volume. Other than the mounting stud lengths has anyone dealt with this? I also have a deep sump addition to add, along with a remote oil cooler and fan set up. Am I shooting myself in the foot, or on an ok track? Damn hot down here in South Texas. Rebuilding engine from 1.7 . Standard 66 crank, 96mm c/p, 1.7 heads with 42 and 36 valves, at this time Webers, but who knows. Any help is welcomed, Jon
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,596 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Here is what I use....
SCHADEK Type 4 Oil Pump The pumps are nicely made. Tight tolerances, and plenty of volume. You can get them in 30mm too, but I don't think that is necessary for our cars. |
jb57tub |
Here is what I use.... SCHADEK Type 4 Oil Pump The pumps are nicely made. Tight tolerances, and plenty of volume. You can get them in 30mm too, but I don't think that is necessary for our cars. Thank you for your response Clay. Just seems like cheap insurance to a possible problem down here. My p/c are from AA, This will just be a daily Porsche fix. I had 15 of them , 6 being 914s, (1 being picked up from the factory in Osnabrueck in '72. |
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
Make sure you take a bit off the drive tang as it's a bit long for a Type IV. The cover will likely need a corner cut off too... Lot's of us running Type I pumps on our cars. Hell, I'm using the CB Performance Dry Sump Pump on mine!
80’s old school |
Member ![]() ![]() Group: Members Posts: 79 Joined: 26-March 19 From: California Member No.: 22,994 Region Association: Southern California ![]() |
Trying to determine if a T1 oil pump is replacement for the T4. I think they put out a little more volume. Other than the mounting stud lengths has anyone dealt with this? I also have a deep sump addition to add, along with a remote oil cooler and fan set up. Am I shooting myself in the foot, or on an ok track? Damn hot down here in South Texas. Rebuilding engine from 1.7 . Standard 66 crank, 96mm c/p, 1.7 heads with 42 and 36 valves, at this time Webers, but who knows. Any help is welcomed, Jon Hope you go with an aftermarket cam. I have a 1911. 66 crank and 96 c/p. Mine has a stock cam and I have 40mm Weber’s. Great running engine, but runs out of grunt after 4800 RPM’s. Lots of midrange torque though. |
jb57tub |
Trying to determine if a T1 oil pump is replacement for the T4. I think they put out a little more volume. Other than the mounting stud lengths has anyone dealt with this? I also have a deep sump addition to add, along with a remote oil cooler and fan set up. Am I shooting myself in the foot, or on an ok track? Damn hot down here in South Texas. Rebuilding engine from 1.7 . Standard 66 crank, 96mm c/p, 1.7 heads with 42 and 36 valves, at this time Webers, but who knows. Any help is welcomed, Jon Hope you go with an aftermarket cam. I have a 1911. 66 crank and 96 c/p. Mine has a stock cam and I have 40mm Weber’s. Great running engine, but runs out of grunt after 4800 RPM’s. Lots of midrange torque though. Will be putting in new cam, will have to figure out which one. Using an old Supertrap exhaust, think I am probably going to with something like Fitech injection set up. Just thinking now but would like the tech help and simple system. Have Dell 44s but will most likely dump them. I have a big bore 2 ltr motor that came out of my car that was built back in the 90s in Cali, Big bore, (don't know the cyl bore yet) big stroke, heavy duty p/c, no bump rods, but just figuring out what I have. Just found a note to the builder, Bernie Bergman, Escandido, Ca. I have the engine torn down , but have not measured it yet. |
Lo-Fi Version | Time is now: 1st July 2024 - 06:57 AM |
