 Forum Rules Classified Rules!
> Sold! Signal Orange 1970 914-6, real -6 with steel GT flares, 70' 2.2S MFI engine, Numbers matching car comes with original longblock.
Dominic
post Oct 7 2019, 09:44 PM
Dominic
12/07/2019 UPDATE: SOLD!
11/26/2019 UPDATE: Sale Pending!
10/13/2019 UPDATE: Added more details / info and pictures to the last few posts.
For Sale:
I have decided to sell my 914-6, I have owned the car almost 5 years and have put less than 1000 miles on it in that time. I have come to the realization that I have too many projects / cars and not enough time.
This is an original 6 that was restored several years back with Steel GT flares
Paint: Signal Orange (Original Color)
Engine: 1970 2.2S MFI engine rebuilt by Denny Aker's in Seattle
Exhaust: Stock 914-6 heat exchangers with modified 911 muffler for 2 in / 2 out.
Trans: Side Shift transaxle, stock -4 gear ratios, GT Torque Biasing Diff, J-west side shift linkage update
Brakes: Front: 911S Alloy Calipers, Rears: 914-6 GT mod with drilled / vented rotors on all four corners
Wheels: Fuchs 15x7" Fronts, 15x8" Rears (comes with 15x8" spare)
Interior: Momo Prototipo wheel, GTS classic seats with houndstooth inserts, Nakamichi CD player with removable face and aftermarket speaker pods.
Body / Exterior: Steel fender flares, steel rocker panels modified for flares, steel front valance modified for flares, GT engine lid built by Sergio Meza, Hella Euro lenses front and rear. Re-chromed front and rear original bumpers with license plate holed welded up on front bumper (high quality chrome work, you have to see these to appreciate how nice they are), new / perfect rubber bumper tops. Original side view mirror (drivers side only)
Battery: Odyssey PC680 dry cell battery, rennline battery holder, hella battery cut-off switch, relocated to front trunk (see pics).
Original Numbers matching 2.0L longblock included
COA included with car along with large folder of records.
Asking: $79,000
*Update: 11/12/2019 Lowered price to $75,000.
Serious buyers will have to PM me with an actual phone number, internet scammers can F#ck-off (IMG:style_emoticons/default/mad.gif)
I will add more pics and details in the coming days.
As promised here is a list of items I have replaced since I have owned car.
Work Performed Summer 2015:
Installed new speedometer cable
Installed new J-West side shifter linkage
Install late style parking brake handle
Installed 944 inertia reel seat belts
Installed new Hella Euro front turn signal lenses
Replaced front sway bar drop links with adjustable units
Replaced front suspension bushings
Replace oil pressure sender with new VDO 0-80 psi sender to match gauge
Replace fuel tank sending unit with new VDO part
Rebuilt pedal cluster with new bronze bushings, new clutch shaft and spring.
Replaced right targa bar window seal
Replaced Fuel Filler Cap seal
Replaced old “914-6” emblem with NOS gold 914-6 script
Installed new 12v power adapter under dash (for GPS/phone charger)
Repainted petals all four Fuchs wheels with aluminum paint (RSR look)
Remove muffler, cleaned, re-welded tail pipe, painted with grey ceramic paint
Replaced MFI fuel filter in engine compartment
Installed New Rear adjustable Koni shocks with coil over kit (175 lbs springs)
Work performed Summer of 2018:
Removed engine / Trans / Oil tank / Fuel Tank
Installed New front motor mount
Installed New Engine Comp Rubber Seals
Installed new stainless steel fuel lines through tunnel.
Installed new oil supply line from oil tank to engine.
Adjusted valves, replaced valve cover gaskets with new silicon units (no leaks)
Replaced alternator / alternator belt.
Media blasted 11 blade fan and clear coated fan
Installed new 123 Ignition programmable blue tooth Distributor
Replaced rear brake hosed with new DOT Stainless steel lines.
Cleaned and Tested all MFI injectors, replaced one bad injector
Installed new IMI Hi-Torque Starter
Recent Work Performed:
Replaced alloy lug nuts - Oct 2019
Installed new Odyssey PC680 Battery – Oct 2019
Installed New first / Reverse Slider and 1st gear syncro – Oct 2019
Replies(1 - 19)
raynekat
post Oct 8 2019, 12:22 AM
Looks like a great ride there Dominic.
GLWTS
You should add a few more pics of like the interior, engine bay, trunks, etc.
Bruce Hinds
post Oct 8 2019, 05:43 AM
V-8 madness
WOW - If I could afford a 6 that would be the one!
If it doesn't stay in our "family" I'd love to see what it goes for on BAT. The prices are staggering.
Cairo94507
post Oct 8 2019, 07:47 AM
Michael
Great looking Six- GLWTS. (IMG:style_emoticons/default/beerchug.gif)
pete000
post Oct 8 2019, 10:12 AM
DON'T SELL IT !!
BuddyV
post Oct 8 2019, 10:44 AM
Robert
…. original motor … included?
Dominic
post Oct 8 2019, 10:32 PM
Dominic
More pics of Interior...
EdwardBlume
post Oct 9 2019, 07:07 AM
QUOTE(BuddyV @ Oct 8 2019, 09:44 AM) *
"Original Numbers matching 2.0L long block included"
Great car. Great price.
This car is a flippers paradise.
This car is perfect in every way....
GLWTS
Mike Fitton
post Oct 9 2019, 08:09 AM
Looks like the Tach and combo gauge are non-original, is the speedometer original? Do you have original gauges? Does the dash have a cap on it, hard to tell from pictures.
Rufus
post Oct 9 2019, 11:02 AM
This appears to be an awesome 914/6 ... I love it!
GLWTS
BTW: Which transmission does it have?
a9146luvr
post Oct 9 2019, 11:30 AM
If this is a "/car" that you are selling, i would really like to see the "project/" that you are keeping! Very nice! (IMG:style_emoticons/default/pray.gif)
JOEPROPER
post Oct 9 2019, 11:54 AM
The answer is "no" unless you ask...
QUOTE(a9146luvr @ Oct 9 2019, 01:30 PM) *
(IMG:style_emoticons/default/agree.gif) Love this car. I just printed out the 3 first pictures of the add in hopes of having mine turn out like this. Beautiful car GLWS.
BTW is the sail panel painted?
flat4guy
post Oct 9 2019, 08:37 PM
Beautiful car - it's always a timing issue with me when the cool ones come up for sale. (IMG:style_emoticons/default/sad.gif)
Dominic
post Oct 9 2019, 09:00 PM
Dominic
QUOTE(Mike Fitton @ Oct 9 2019, 07:09 AM) *
Yes, someone once told me the Tach was a 911 Turbo tach with the boost converted to the oil pressure gauge. The dash is a very nice original dash pad (not a cap).
I did not build the car so I don't know all of the details.
Some More Pics...
Dominic
post Oct 13 2019, 04:22 PM
Dominic
More pics.. last one shows the rear trunk panel with the original chasis number stamping.
sixnotfour
post Oct 29 2019, 11:45 AM
I bought it out of a Barn 1998?? 2011 BAT
https://www.flickr.com/photos/37210452@N06/...157628092486963
more intel.
http://www.914world.com/bbs2/index.php?s=&...t&p=2758019
RSWannabe
post Nov 8 2019, 01:48 PM
I just had this ad brought to my attention. I'm the one who did the restoration on this car and sold it on BaT in 2011. Damn it's good to see it. Glad to see its been well maintained and continued to be improved.
Question for seller, When I sold it, it had a close ratio gear set in it. A, F, Ka, Q, X if I recall correctly. Was that swapped out for stock 4 gears or was the whole transmission swapped?
Dominic
post Nov 8 2019, 07:44 PM
Dominic
QUOTE(RSWannabe @ Nov 8 2019, 11:48 AM) *
Just the gears were swapped out, it still has the GT Torque Biasing Differential.
Thanks,
Dominic
Dominic
post Nov 12 2019, 08:44 PM
Dominic
ben*james
post Nov 26 2019, 08:38 PM
LIFER
Deposit made
13 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th January 2025 - 09:44 AM
