Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
With the rash of shifting issues popping up doing a GB so you can inexpensively replace all the bushings in one shot even the cover and correct band to keep the crud out.
You will get the 1 cup bushing ( one at the transmission) the bushing at the firewall the knuckle bushing (yes set of 2) the transmission guide bushing the rubber sleeve for the rod at the transmission Option for new cover ... at $8 option for new cover band and hardware at $9 Maybe even a few other options (IMG:style_emoticons/default/biggrin.gif) You know me ..while you are there. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
SteveL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None ![]() ![]() |
Link to the GB? Delivery timeline?
Thanks! |
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,648 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
I need to check a couple of things and see how "far" I need to go but I bet i'm in on the basics if nothing else....so...yeah.
Mikey914 |
Lg914 |
Member ![]() ![]() Group: Members Posts: 53 Joined: 4-July 19 From: Lake Geneva Member No.: 23,275 Region Association: None ![]() |
TitanMZ3 |
Newbie ![]() Group: Members Posts: 6 Joined: 19-September 19 From: Virginia, USA Member No.: 23,479 Region Association: MidAtlantic Region ![]() |
I'm in
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,176 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
Basics for me too put me in
jtprettyman |
Rust Bucket Owner ![]() ![]() Group: Members Posts: 109 Joined: 5-May 15 From: Murfreesboro Tennessee Member No.: 18,707 Region Association: South East States ![]() ![]() |
I'm in - GB on this is great, should consider adding this package as a standard catalog item, very convenient to get everything on one shot.
injunmort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States ![]() |
I am in for all, bushings, covers, hardware, no shifter knob. also need new cone screws. thank you.
gandalf_025 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States ![]() |
How about for a tail shifter....????
SteveL |
I'm in. Adding new cone screws sounds like it would be a good option!
Specracer |
Member ![]() ![]() Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None ![]() |
As usual, a GB hits, but I already bought most of these pieces (all of the bushings). They all worked out perfect. Buy with confidence (duh).
Tbrown4x4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 705 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None ![]() ![]() |
Don't need them yet, but put me down for 1 kit to keep the group buy going.
pt_700 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,095 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California ![]() ![]() |
i'm down for a set for an early body with sideshift trans.
Mikey914 |
second wind |
Senior Member ![]() ![]() ![]() Group: Members Posts: 860 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California ![]() ![]() |
Hello Mikey......Thank you for your help and my kit will arrive soon. Please confirm there is a bushing under the shift lever and what is it called? Is it included in the kit? And what exactly is the firewall bushing? The round rubber bushing in the firewall that the interior shift shaft goes through? Simple questions but I don't know this stuff for sure. thank you very much!
gg |
gandalf_025 |
If the tail shift option is available here,
I’m in and I’m in NO HURRY to get it.. If it takes you time to make some pieces, I’d be glad to wait... Just let me know if I should sign up here and now or wait for a specific Tail Shift Buy.... Thanks for all you do.... |
Mikey914 |
Hello Mikey......Thank you for your help and my kit will arrive soon. Please confirm there is a bushing under the shift lever and what is it called? Is it included in the kit? And what exactly is the firewall bushing? The round rubber bushing in the firewall that the interior shift shaft goes through? Simple questions but I don't know this stuff for sure. thank you very much! gg The early cars use a cup bushing in the shift rod (the one the shift knob is on). I may have added some confusion as I had just done my 72 and was thinking early when I initially put this out there. Late side shift would not require the 2nd cup bushing. The firewall one is at the bulkhead and is under the rubber bellows. I’m working on having an option to add the cone screws for those that need / want them. I plan to open this up Monday with another GB that you can combine if you so choose. Another inexpensive part many folks are missing. Thanks all just need a few more takers. Thanks, Mark |
Mikey914 |
If the tail shift option is available here, I’m in and I’m in NO HURRY to get it.. If it takes you time to make some pieces, I’d be glad to wait... Just let me know if I should sign up here and now or wait for a specific Tail Shift Buy.... Thanks for all you do.... Will be a specific thread. Thanks, Mark |
motorvated |
Member ![]() ![]() Group: Members Posts: 281 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains ![]() |
If the tail shift option is available here, I’m in and I’m in NO HURRY to get it.. If it takes you time to make some pieces, I’d be glad to wait... Just let me know if I should sign up here and now or wait for a specific Tail Shift Buy.... Thanks for all you do.... Will be a specific thread. Thanks, Mark I'm in for one side shift basic kit. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:19 PM |
