GB engine tin delete plugs Closes 12/31/19, PN 914.559.243.10 $6 a pair Confirmed These fit perfectly LIke OEM |
Mikey914 |
Dec 9 2019, 02:37 AM
The rubber man Group: Members Posts: 12,742 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These are the delete plugs used on the 914/6 to eliminate the rain tubes as there is no rain tray on it.
They are also used on the early cars including 73 from what I can see on PET Stopper -73 1 914-4/1,7 for 914-2,0 Oil hose And Water drain sleeve 13 Stopper -73 2 914-6 for Oil hose And Water drain sleeve These are located in the Hell hole area and under the relay board. I'll post pictures up Monday afternoon, but if you have holes there these are what should be plugging them They are not on the low point, but on the part sloping down. Made from Nylon to the correct dimension like factory not a cheap plug that kind of fits At $6 a pair who's in? |
rick 918-S |
Dec 9 2019, 05:22 AM
Hey nice rack! -Celette Group: Members Posts: 20,840 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:style_emoticons/default/assimilate.gif) in for four
BeatNavy |
Dec 9 2019, 07:01 AM
Certified Professional Scapegoat Group: Members Posts: 2,945 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Do you have a pic of what they are supposed to look like? I found something like what you're describing all covered in undercoating, so I thought maybe it was some sketchy repair the DAPO did or something. Glad to hear it may be legit.
What the hey, I'm in for at least a pair. |
mb911 |
Dec 9 2019, 07:53 AM
914 Guru Group: Members Posts: 7,417 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Me please
porbmw |
Dec 9 2019, 09:14 AM
Senior Member Group: Members Posts: 813 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
In for a pair
THanks, Mark! Paul |
Mikey914 |
Dec 9 2019, 10:02 AM
Do you have a pic of what they are supposed to look like? I found something like what you're describing all covered in undercoating, so I thought maybe it was some sketchy repair the DAPO did or something. Glad to hear it may be legit. What the hey, I'm in for at least a pair. I'll post up shortly, but yes most of there are missing or covered over with crap if they are still there. Just another part you didn't know you even needed (IMG:style_emoticons/default/biggrin.gif) |
sixnotfour |
Dec 9 2019, 10:33 AM
914 Wizard Group: Members Posts: 10,704 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/beerchug.gif) plus one more -73 where the six oil line goes through shelf to lower tank fitting,,, right side of pic.,If not a six..
Attached image(s) |
johnlush |
Dec 9 2019, 11:36 AM
What's all this then? Group: Members Posts: 372 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,108 Region Association: Rocky Mountains |
I'm in for 2 pair. -John
Mark Henry |
Dec 9 2019, 11:54 AM
(IMG:style_emoticons/default/beerchug.gif) plus one more -73 where the six oil line goes through shelf to lower tank fitting,,, right side of pic.,If not a six.. (IMG:style_emoticons/default/agree.gif) That's one I'd definitely be interested in. |
BPic |
Dec 9 2019, 11:55 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I’m in for a pair please!
RoadGlue |
Dec 9 2019, 12:41 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Running a GT lid, so I'm in. Thanks!
Lg914 |
Dec 9 2019, 12:57 PM
Member Group: Members Posts: 53 Joined: 4-July 19 From: Lake Geneva Member No.: 23,275 Region Association: None |
Count me in for a set
rudedude |
Dec 9 2019, 02:03 PM
Senior Member Group: Members Posts: 518 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I'll take 2 sets
sbsix |
Dec 9 2019, 02:58 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 455 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
In for a set.
johnhora |
Dec 9 2019, 04:47 PM
Senior Member Group: Members Posts: 877 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
I'll take a pair...Thanks
bob164 |
Dec 9 2019, 05:23 PM
Member Group: Members Posts: 97 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
I will take 4.
bdstone914 |
Dec 9 2019, 05:45 PM
bdstone914 Group: Members Posts: 4,744 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Do you have a pic of what they are supposed to look like? I found something like what you're describing all covered in undercoating, so I thought maybe it was some sketchy repair the DAPO did or something. Glad to hear it may be legit. What the hey, I'm in for at least a pair. The originals I have are an opaque dome shaped cap plug. Can post a picture when I find them. |
rgalla9146 |
Dec 9 2019, 06:26 PM
Advanced Member Group: Members Posts: 4,676 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
here you go......and while your at it, how about the oval block-off ?
wish I had a better example....the only one I have has been tortured. Attached thumbnail(s) |
BeatNavy |
Dec 9 2019, 06:33 PM
Yes, cool, that's helpful. Those are definitely on my tin (covered up with a bunch of old undercoating, paint, and other crap). I'm glad those are stock and not evidence of some poorly done repair.
This GB comes at a good time. Yes, another part I didn't know I needed (IMG:style_emoticons/default/smile.gif) |
rgalla9146 |
Dec 9 2019, 06:39 PM
These are the delete plugs used on the 914/6 to eliminate the rain tubes as there is no rain tray on it. They are also used on the early cars including 73 from what I can see on PET Stopper -73 1 914-4/1,7 for 914-2,0 Oil hose And Water drain sleeve 13 Stopper -73 2 914-6 for Oil hose And Water drain sleeve These are located in the Hell hole area and under the relay board. I'll post pictures up Monday afternoon, but if you have holes there these are what should be plugging them They are not on the low point, but on the part sloping down. Made from Nylon to the correct dimension like factory not a cheap plug that kind of fits At $6 a pair who's in? I've never seen a 4cyl car with the hole for the oil hose under the relay board. |
Lo-Fi Version | Time is now: 14th January 2025 - 08:11 AM |
