advman89 |
Member ![]() ![]() Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest ![]() ![]() |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,911 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
I would just paint them with high temp semi gloss paint and use white metal polish on the rim. For the cost of powder painting you could buy a new set
advman89 |
Perfect. That's where I was headed.
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
I had the same wheels on my car when I got it and did that same thing, stripped off 3 layers of paint, down to metal then primer and paint black looked really nice. But offset is not right for the car so dot put in big wheels you will rub
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Get the wheels centres really clean and apply a coat of etch primer, the topcoat will stick better.
Good luck. |
Lo-Fi Version | Time is now: 24th June 2024 - 06:14 AM |
