malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Looking to build a 2.0 out of a 1.8. I have a crank, but I am struggling with the measurements, so just in case, I figured I would place and ad.
Again, Looking for standard Main and Rod journals. Let me know, Clark |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,978 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
bump -- Anyone got a Std. crank for Malcolm2?
yostcorners |
Newbie ![]() Group: Members Posts: 1 Joined: 14-March 19 From: peachtree corners, ga Member No.: 22,957 Region Association: South East States ![]() |
Looking to build a 2.0 out of a 1.8. I have a crank, but I am struggling with the measurements, so just in case, I figured I would place and ad. Again, Looking for standard Main and Rod journals. Let me know, Clark I may have one. PM the measurements you are looking for. Thanks, Jon. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,918 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Check over at theSamba.com
malcolm2 |
Thanks. I searched yesterday. Have a WTB there too. I have time so i’ll keep searching snd bumping (IMG:style_emoticons/default/smile.gif)
malcolm2 |
Looking to build a 2.0 out of a 1.8. I have a crank, but I am struggling with the measurements, so just in case, I figured I would place and ad. Again, Looking for standard Main and Rod journals. Let me know, Clark I may have one. PM the measurements you are looking for. Thanks, Jon. Will do. @yostcorners and other curious folks. the Tom Wilson book has the dims for type 4 crankshaft as follows for standard in inches and mm: Main-Bearing Crank Journal Diameters 1,7, 1.8 and 2.0 liter #1 thru #3 2.3609" to 2.3617" (59.971 mm to 59.990 mm) #4 1.5739" to 1.5748" (39.984 mm to 40.000 mm) Rod-Bearing journal diameter for 2 liter 1.9677" to 1.9681" (49,97 mm to 49,98 mm) |
yostcorners |
Looking to build a 2.0 out of a 1.8. I have a crank, but I am struggling with the measurements, so just in case, I figured I would place and ad. Again, Looking for standard Main and Rod journals. Let me know, Clark I may have one. PM the measurements you are looking for. Thanks, Jon. Will do. @yostcorners and other curious folks. the Tom Wilson book has the dims for type 4 crankshaft as follows for standard in inches and mm: Main-Bearing Crank Journal Diameters 1,7, 1.8 and 2.0 liter #1 thru #3 2.3609" to 2.3617" (59.971 mm to 59.990 mm) #4 1.5739" to 1.5748" (39.984 mm to 40.000 mm) Rod-Bearing journal diameter for 2 liter 1.9677" to 1.9681" (49,97 mm to 49,98 mm) Hello Malcolm. I have what you are looking for. Please call 404 838 7444. Thanks, Jon. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:56 AM |
