Interesting 914-6 conversion on Ebay. What's it worth? |
raynekat |
Dec 19 2019, 05:53 PM
Advanced Member Group: Members Posts: 2,167 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
https://www.ebay.com/itm/1973-Porsche-914/2...YEAAOSwJcNd-QS-
Looks pretty nice excepting the wheels and mirrors. 3.2 with flares and a lot of nice accoutrements (IMG:style_emoticons/default/wink.gif) Nearly $70k ???? What say thou? |
bretth |
Dec 19 2019, 06:14 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I saw this on the local Craigslist here. Have no knowledge of it though. I hate when listings include no photos of the engine what so ever. The motor could be an oily, leaky mess with broken head studs for all anyone would know.
ClayPerrine |
Dec 19 2019, 06:37 PM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I know.
The car belongs to Mike Floyd here in the DFW area. He posts on here occasionally. That is a frame off rotisseree restoration, and everything is done right. The engine is a Euro 3.2. No broken head studs, no oily mess, just an excellent running and driving 914. Interior is leather. Power windows. Everything is done to a 10/10ths standard. I would call it a civilized version of my six conversion. I would buy it, but I don't have a place to park it inside. |
ClayPerrine |
Dec 19 2019, 06:43 PM
From Mike:
1974 914 6 Conversion Rotisserie, bare metal body work for repaint. It is not perfect. If you want to go to Pebble Beach, keep looking, but it is a virtual rust free chassis. Antenna hole welded up and I can't bring myself to drill another! The paint has some chips and bug bites but is quite presentable. Steel flares butt welded Chrome bumpers redone about 4 years ago with fresh bumper tops. 17x7.5 and 17x9 on rear with Michelin Pilot tires less than 2 years old. For you "Fuch-er lovers", I will include a set of 16x8/7 wheels Aluminum cross member,20mm(turbo 911) front sway and stock 914 sway bar in rear, 19mm 911 front torsion bars, 150lb springs on coilover adjustable rear shocks, Boxster brakes with functioning parking brake on rear, Shocks replaced with body work, suspension bushings sized in front and rear suspension, Stainless steel fuel lines replaced factory plastic lines thru the cabin. 901 side shift, LSD, billet intermediate plate, etc in good shape. Getty 5 gauge dash, leather upholstery, German square weave carpet less than a year old, Fiberglass door panels recovered, Blaupunkt is NOS 1973 or so, AM only which was modified on the inside for AM/FM or memory stick with 40 amps of power to each of the four channels, face of radio looks absolutely stock. Windshield is almost new. ECU under the passenger seat. Driving lights have separate circuit breaker with 8 ga. wire to front and the solenoid is switched by the stock system which takes the amperage load off the stock system. Some new LED lights would remove the load problem and would be my next thing to tackle if I was going to keep it. Those big driving lights get hot! Euro, 930/20, 3.2 with stock 10.3 compression pistons, Web 20/21 cam, chipped, B&B SS headers with heat and 1 3/4" primaries, rally 2 in/2 out muffler. Stock oil tank and location. Auxiliary Mocal oil cooler under rear of car with thermostat, and fan. Original 6 front motor mount, A/C mount on engine, but no compressor, Wes Hildreth, H&H Enterprises Plano,TX, disassembled the engine about 8 years ago to inspect, repair and replace as required. Wes was the dealership's "bench mechanic" who rebuilt engines and transmissions for the Porsche store here in Dallas and then opened his own shop. God called Wes home about 4 years ago. Car is good to go anywhere and will go there very, very quickly for a 914 and enjoys the reliability of the 3.2 stock fuel injection. Car has not been tracked for DE or raced. I had a vintage 914 E production car I raced with CVAR for over a decade to satisfy my aggression and testosterone issues!! This car is a nice high speed cruiser. Fifth Gear in Denton did a 4 wheel alignment a couple years back and corner balanced it. I turn 70 soon and health is an issue. I will purchase something abit higher off the ground with air conditioning and a warranty. This is the last of 5 P cars to go and it will be hard. |
ClayPerrine |
I have a bunch of pictures if you want me to post them.
Cairo94507 |
Dec 19 2019, 06:57 PM
Michael Group: Members Posts: 10,130 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That looks to be a top drawer 914-6 conversion. Would I change a couple cosmetic things, sure. But that car is good to go as is and whom ever is luck enough to buy it will no doubt love it. GLWTS. (IMG:style_emoticons/default/beerchug.gif)
rgalla9146 |
Dec 19 2019, 07:39 PM
Advanced Member Group: Members Posts: 4,671 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Beautiful car.
Must be alot of fun ! |
914werke |
Dec 20 2019, 05:14 AM
"I got blisters on me fingers" Group: Members Posts: 11,030 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I like the cup 1's not so much the mirrors
sixnotfour |
Dec 20 2019, 07:42 AM
914 Wizard Group: Members Posts: 10,681 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I need a decibel reading reading of the interior at 75 mph...to even consider... (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif)
SKL1 |
Dec 20 2019, 09:58 PM
Senior Member Group: Members Posts: 1,646 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Looks pretty nice and though I'm a rose petal Fuchs guy, those wheels look pretty good. I had them on a 964 way back when and always liked them.
Not a fan of a 5 gauge dash on a 914 though- just not right IMHO. But wouldn't kick it out of bed for eating crackers. |
ClayPerrine |
Dec 21 2019, 07:23 AM
Lo-Fi Version | Time is now: 26th December 2024 - 08:39 PM |
