> Removing door panels
63acornwall
post Dec 22 2019, 07:43 AM
looking at the interior of door , no obvious screws to remove door panel and top padded rail ? Is there an existing thread for this ?
Replies(1 - 4)
Garland
post Dec 22 2019, 08:31 AM
Restoration Fanatic
Yes there is, here ya go.
Removing the door card/panel
Jett
post Dec 22 2019, 08:33 AM
Door panels are all one piece with screws holding the arm rest(sj and drivers door compartment. Once the arm rests are removed, there are plastic clips every few inches that need to be gently popped out without bending the door card too much. The top bolster portion of the door card has three metal tabs that attach at the top of the door and once you have the plastic tabs free you simply slide the door card up and out.
Added picture to help see what is inside
barefoot
post Dec 22 2019, 08:34 AM
Both sides, there are 3 screws along the bottom of the armrests, then then there are plastic plugs along F & rear sides that will pop out. then lift vertically to release tangs along the top edge. Of course, the window crank & the recess under the interior lock/opener handle screws need to com out. The window crank plastic cover will lift away for access to the screw under.
914 rubber sells new plastic & silicone bits that will probably break when you pull the door cards away.
63acornwall
post Dec 22 2019, 08:42 AM
Thanks guys , that is really quick and helpful .
BTW I am not very skilled with the search engine , it returns a lot more than I can cope with , so appreciate the help !
- Lo-Fi Version Time is now: 26th December 2024 - 10:33 PM
