> 0-60 for a 914/6 with 3.2?
Tdskip
post Dec 22 2019, 01:45 PM
The numbers are secondary to the driving experience of course, but just curious if anyone’s ever benchmark to their conversion against a stopwatch?
4 Pages V  1 2 3 > »
Replies(1 - 19)
gms
post Dec 22 2019, 01:54 PM
QUOTE(Tdskip @ Dec 22 2019, 01:45 PM) *
A 911 runs 6.1 sec so lighter car with shorter gears probably mid 5 sec
post Dec 22 2019, 01:56 PM
Resident German
QUOTE(Tdskip @ Dec 22 2019, 11:45 AM) *
I did some timed runs with my 3.6L and the biggest problem was getting the tires to hook and not spin.
I don't use 1st gear at all and take off in 2nd and if i'm not careful i can still lay down 10 yards of rubber. That might look cool but it doesn't do you any good in terms of actually moving forward.
The best time i got (that one time everything went perfect) was just under 4 seconds.
Tdskip
post Dec 22 2019, 02:02 PM
@SirAndy - WOW.
Thanks @GMS .
Lunching first gear is probably the biggest issue on the time.
Coondog
post Dec 22 2019, 02:38 PM
I would think a six mated to a 915 trans would show much better 0 to 60 numbers.
post Dec 22 2019, 02:52 PM
914-6 GT in waiting
QUOTE(Coondog @ Dec 22 2019, 03:38 PM) *
Correct. I’ve driven a bunch of light weight 911’s with hot 3.2’s and 915 trans and it’s a blast. No tip toeing around first and slipping the clutch to start in second. But unfortunately it’s a lot more work and money to do it in a 914.
Steve Timmons/Instant-G/3.6 conversion shop took me out in one of his hot 3.8 cars and it was a whole nother level. BIG torque. He showed his transmission no mercy and it held up fine.
Tdskip
post Dec 22 2019, 02:56 PM
And quite likely to live a longer life!
In the real world it’s more about roll-on power anyway.
I don’t really care, per se,about what the actual number is, it’s more of a question driven by trying to calibrate that white 914/6 that I drove and what would be an expected range for the 3.2 L build that I’m doing.
post Dec 22 2019, 02:59 PM
914-6 GT in waiting
What was done to the 3.0. It could be stronger than a stock 3.2.
post Dec 22 2019, 03:12 PM
Resident German
QUOTE(mepstein @ Dec 22 2019, 12:52 PM) *
Taking off in 2nd has the advantage that you don't need to shift at all. The stock 901 gearing will get you from 0 to 60 without shifting (With the appropriate redline and wheel/tire sizes).
The 901 seems to be able to handle the torque just fine if you skip 1st ...
Superhawk996
post Dec 22 2019, 04:51 PM
QUOTE(SirAndy @ Dec 22 2019, 02:56 PM) *
Not bad . . . but you need AWD! (IMG:style_emoticons/default/laugh.gif) There is a reason the 959 had AWD.
Tractive effort quickly becomes the limitation unless you're willing to run 18" wide rear rubber and to deal with the issues rubber that wide brings with it.
Don't get me wrong guys, but, the reality is EV's have changed the game. Any 16 year old driving a Tesla Model S P100D AWD can do 0-60 in 2.5 seconds with absolutely zero drama and zero talent. (IMG:style_emoticons/default/sad.gif) Zero to sixty probably isn't the reason to own a 914.
Just to be clear . . . no ill will meant for you guys with big engines. If I hit the lottery I just might build a 914 with a Singer engine but till then. The art of cornering is where the 914's strenth is at.
Tdskip
post Dec 22 2019, 07:15 PM
QUOTE(mepstein @ Dec 22 2019, 03:59 PM) *
It was certainly a strong engine but I don’t have details on the specs, it was plenty fast just to peaky and raucous for my personal taste.
Tdskip
post Dec 22 2019, 07:17 PM
QUOTE(SirAndy @ Dec 22 2019, 04:12 PM) *
Thanks @SirAndy , I will keep that in mind.
Tdskip
post Dec 22 2019, 07:25 PM
QUOTE(Superhawk996 @ Dec 22 2019, 05:51 PM) *
@Superhawk996 - I could care less what the actual zero-60 number is, it’s more the feel that I’m trying to get a sense of. I doubt I’ll be doing any violent acceleration in the car, it’s the sensation of the unburstable torque and how that moves the car along that I’m really after. It’s hard to describe what it feels like, but you guys get it
The 3.2 L in the 74 911 has that feeling, trying to imagine that in the 914. I certainly didn’t need that white 914/6 to be any faster than it was, it was plenty fast but didn’t have the experience I was looking for.
@mepstein - The engine in that white car felt like it was built for burst of acceleration rather than rolling-on power, if that makes sense.
IronHillRestorations
post Dec 22 2019, 08:15 PM
I. I. R. C.
The 3.0 car I had years ago ( @GMS drove it) would do 0-50 in 5 sec or less with crude measuring equipt. The rev limiting rotor would hit the wall around 57 mph in 2nd gear, so shifting twice is really going to slow you down, unless you don't care about damaging the car. That engine had tons of torque, three different people accidentally started from a stop in 3rd and didn't stall or kill the clutch, and 3rd tach'd out around 75 mph
Steve
post Dec 22 2019, 08:26 PM
3.6 or v8 cars have no problems starting off in second with the 914 gear box. With my 3.2 and a 914 gearbox, I had to slip the clutch to start off in second and first gear was worthless. I have more money in my 915 gear box then my 3.2 motor, but for me it was totally worth it to have a useable first gear and a trans that matches the motor.
Coondog
post Dec 22 2019, 08:46 PM
QUOTE(Steve @ Dec 22 2019, 06:26 PM) *
I agree Steve, our cars are identical except for the trans and you had me beat off every stop light on PCH and we were just cruising.
Superhawk996
post Dec 23 2019, 03:15 AM
QUOTE(Tdskip @ Dec 22 2019, 08:25 PM) *
@tdskip
You're describing what comes with instantaneous torque. If you haven't driven a Tesla go drive one for a baseline. Don't get me wrong I'm not trying to put you in one but EV's have that instant torque and instant acceleration you're seeking.
IMHO EV's have no soul and handle like pigs but that that is the nature of carrying around massive battery packs. Tesla supposedly working on a 3 motor Plaid mode with torque vectoring. That could become a handling game changer.
Tdskip
post Dec 23 2019, 07:23 AM
QUOTE(Superhawk996 @ Dec 23 2019, 04:15 AM) *
Good morning @superhawk996 .
I have, neat cars, but not what I am after or trying to describe.
I was just looking for some calibration, which I think has been provided here, as well as some good tips on not lunching first gear.
Thanks gentlemen!
Superhawk996
post Dec 23 2019, 08:09 AM
QUOTE(Tdskip @ Dec 23 2019, 08:23 AM) *
Thanks gentlemen!
@Tdskip
(IMG:style_emoticons/default/sad.gif) I feel like I let you down . . . (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/rolleyes.gif) Oh well, at least I didn't end up convicing you to buy a Tesla. (IMG:style_emoticons/default/lol-2.gif)
Tdskip
post Dec 23 2019, 08:21 AM
No worries @superhawk996 , all good.
Have a good day folks!
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 27th December 2024 - 06:13 AM
