Question about seat removal, Help needed |
Thunderchief |
Dec 23 2019, 01:27 PM
Member Group: Members Posts: 154 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
I'm in the process of removing my interior and I've gotten the passenger's side seat out. The driver's seat though is moved all the way back and the slide mechanism is broken. So in the back of the seat, I can barely access the outside track bolts but can't even feel the inside track's bolts. I ordered a new slide handle but I'm not sure I can fully get to it to change it out until I get the seat out. Thanks.
dr914@autoatlanta.com |
Dec 23 2019, 01:50 PM
914 Guru Group: Members Posts: 8,110 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
slide it all of the way forward reaching under the broken seat loop until it stops then move back slightly and reach under the outer track next to the rocker carpet and release the tension clip then holding it up as well as the loop side, slide the seat out
I'm in the process of removing my interior and I've gotten the passenger's side seat out. The driver's seat though is moved all the way back and the slide mechanism is broken. So in the back of the seat, I can barely access the outside track bolts but can't even feel the inside track's bolts. I ordered a new slide handle but I'm not sure I can fully get to it to change it out until I get the seat out. Thanks. |
Thunderchief |
Dec 23 2019, 01:52 PM
Hi George,
Thanks for the reply but how can I slide it forward if the slide handle is broken. Is there another way? |
mepstein |
Dec 23 2019, 01:55 PM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just use a screwdriver or your fingers to pull up on the broken lever that would normally have the metal loop.
Thunderchief |
Dec 23 2019, 02:05 PM
Well that was super easy! Thanks guys!
Dec 23 2019, 02:23 PM
Lo-Fi Version | Time is now: 26th December 2024 - 06:19 PM |
