> Throttle to Plenum seal
PCH
post Dec 23 2019, 02:27 PM
When placing a new throttle body to plenum gasket, do you put some sort of sealer (like Formagasket) on the gasket?
The previous gasket had a sealer on it.
Thank you for your help.
Peter
Replies(1 - 7)
rjames
post Dec 23 2019, 04:29 PM
I'm made of metal
QUOTE(PCH @ Dec 23 2019, 12:27 PM) *
When placing a new throttle body to plenum gasket, due you put some sort of sealer (like Formagasket) on the gasket?
Peter
You shouldn’t need it if the surfaces of the TB and plenum are super clean. Torque down the bolts each a little at a time.
rjames
post Dec 23 2019, 04:31 PM
I'm made of metal
Double post
DRPHIL914
post Dec 23 2019, 09:37 PM
Dr. Phil
Common spot for vac leak, there is a gasket that should be placed between there at least I have always had one on my 2.0 D-jet
iankarr
post Dec 23 2019, 10:34 PM
A thin smear (thin!) of The Right Stuff can’t hurt.
rjames
post Dec 23 2019, 11:16 PM
I'm made of metal
QUOTE(DRPHIL914 @ Dec 23 2019, 07:37 PM) *
Gasket yes. Goop isn’t needed if surfaces are properly prepped.
DRPHIL914
post Dec 24 2019, 08:26 AM
Dr. Phil
QUOTE(rjames @ Dec 24 2019, 12:16 AM) *
(IMG:style_emoticons/default/headbang.gif) Sorry, it was late and I was not reading clearly the OP, lol but I agree o goop needed just gasket-
PCH
post Dec 24 2019, 01:43 PM
Thanks everyone for your help!
- Lo-Fi Version Time is now: 26th December 2024 - 11:42 PM
