Replacing Flywheel Bolts, Is it really necessary? |
motorvated |
Jan 3 2020, 09:26 AM
Member Group: Members Posts: 282 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
I'm changing out my flywheel and would like to know if it really is necessary to replace the mounting bolts. I know that some bolts are supposed to stretch when torqued down and are considered as one time use. But the flywheel mounting bolts don't seem to be that type, so can they safely be re-used? Should Locktite be used on them if new or re-used?
PeeGreen 914 |
Jan 3 2020, 09:36 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
No, you don't need to change them out. It is recommended but few rarely do. Yes, use Locktite on them.
motorvated |
Jan 3 2020, 09:38 AM
anderssj |
Jan 3 2020, 09:50 AM
Dog is my copilot... Group: Members Posts: 1,716 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Bolts can probably be reused, but be sure to replace the locking plate/disc (PN 021105275).
Photo at: https://www.thesamba.com/vw/classifieds/pix/8355850.jpg Hope this helps. Steve A- |
motorvated |
Jan 3 2020, 10:27 AM
Bolts can probably be reused, but be sure to replace the locking plate/disc (PN 021105275). Photo at: https://www.thesamba.com/vw/classifieds/pix/8355850.jpg Hope this helps. Steve A- Good suggestion. I'll be sure to do that. Thanks! |
iankarr |
Jan 3 2020, 12:43 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,532 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I changed out mine...but only because I figured after 45 years it couldn't hurt. The old bolts looked fine though. I think a new locking plate is more critical. You can see the scratches in the plate dug in by the bolts in my clutch replacement video...
jmitro |
Jan 3 2020, 01:05 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I guess I'd rather spend a few extra bucks to change them out and do it correctly than second guess the factory recommendations.
I installed new bolts when I changed the clutch on my Boxster. TBH I'm not sure if it's recommended for the 914, but if so then I would buy new bolts and install them correctly |
Mark Henry |
Jan 3 2020, 01:28 PM
Bolts can probably be reused, but be sure to replace the locking plate/disc (PN 021105275). Photo at: https://www.thesamba.com/vw/classifieds/pix/8355850.jpg Hope this helps. Steve A- Yes they can be reused. Also besides the locking plate replace the RMS, flywheel o-ring, felt washer and pilot bearing. |
Lo-Fi Version | Time is now: 14th January 2025 - 07:59 AM |
