> Steering wheel and center push interchange?
Tdskip
post Jan 30 2020, 02:15 PM
Hi guys - hope everyone having a good week.
I have several steering wheels and several centers, all separate. Other than just trying to fit them to each other are there part numbers / stamping that indicate what belwkngs together?
Replies(1 - 4)
914Sixer
post Jan 30 2020, 02:24 PM
The base wheel are all the same. Only difference is the mounting hardware. No part numbers stamped except for the horn contact ring on later model. Used VW contact.
914-6 GT in waiting
Any wheel that part number ends in “10” is early, has a flat front and uses a horn push button. The back fits on a Porsche style steering shaft. Wheels that end in “11” are mid and late. They have a bevel on the front. The back fits a VW style shaft. The early horn pads have a flat area for the horn button. The mid and late have a little tab for a horn wire.
dr914@autoatlanta.com
post Jan 30 2020, 02:47 PM
the steering wheels are all the same except for the numbers, for the plastic ones and the leather ones and the foam ones. However the hubs are different
70-71 914-4 with plastic hub
72-76 with shorter plastic hub
70-71 914-6 with no hub
72 914-6 with shorter plastic hub
the leather wheels follow
Tdskip
post Jan 31 2020, 12:13 PM
Thank you gentlemen – sorry for the belated response .
- Lo-Fi Version Time is now: 5th January 2025 - 03:31 AM
