> Another tire size thread, Let’s see your skins
stevegm
post Feb 1 2020, 03:51 PM
I am sure this has been covered, but I don’t seem to be able to find a general consensus on what tires will fit under the stock fenders. I’d really like to know what size tire you’re running and are happy with.
I believe the 914 originally came with 165HR15 - which were 165/80HR15. But I have seen that a lot of people use 195-65-15. Is that right?
Back in the 80s I think I ran 195-50-15. Or even 205-50-15.
I have stock fenders, and am using Pedrinis. I prefer not to use a spacer.
Suggestions? What are you running? Pictures of your 914 clad in your favorite size?
Replies(1 - 11)
DucRS
post Feb 1 2020, 04:01 PM
After hours of research I found 195’s to be the best fit.
taylspin46
post Feb 1 2020, 04:05 PM
I run 195/50/15 with 3/8” spacers in rear without a problem.
stevegm
post Feb 1 2020, 04:06 PM
QUOTE(DucRS @ Feb 1 2020, 05:01 PM) *
Thanks. 195-50s or 195-60s?
SteveL
post Feb 1 2020, 04:08 PM
I have had 205/60's and 195/165s. the 195/65s fit better and look better on the rims. the 205's were a little too wide for the rim didn't look right.
ndfrigi
post Feb 1 2020, 04:14 PM
I’m planning to buy 195x60 for a replica 2.0 fuch wheels.
I did 205x60 on a 911 6” wide fuch wheels but for 5.5 I think 205 is a little wider.
195x55 kinda low and 195x50 also and gives a stock speedo wrong numbers. And 195x65 is kinda give higher side walls but almost accurate on speedo. Well that is for my own understanding/opinion. Again it all depends how each owner/driver wants it.
Cairo94507
post Feb 1 2020, 04:19 PM
Michael
I went with 195x55xR15 Yokohama tires on my deep 6 wheels and I like the look. It also provides some sidewall to give the car a little protection from the horrible roads here in CA.
post Feb 1 2020, 04:28 PM
914-6 GT in waiting
I have 195x65x15 on 2.0 Fuchs on my 1.7 car and it looks and fits great.
I have 205x60x15 on 5 lug Fuchs on my 3.2 car. One side was a little tight but I pulled it out by hand and it's fine. The 205 look a little too wide if you want a more period correct look.
anderssj
post Feb 1 2020, 05:01 PM
Dog is my copilot...
Goodyear Eagle Sport All-Season, 195/65-15, on Pedrinis. Nice tire, though the car feels slightly less agile/playful compared to the old Vredestein (165/80-15) tires that were on the car. That said, it is definitely more planted...
Plenty of clearance all-around, even with no spacers.
rgalla9146
post Feb 1 2020, 06:17 PM
205 /55 VR 15 on 15 x 6's works with any stock wheel. 4 or 6
DickSteinkamp
post Feb 1 2020, 06:31 PM
I'm finding that the stock 165/15s actually had an 82 aspect ratio...not 80. This makes 195/65/15s 2.7% smaller in diameter than the stock tires. 195/70/15s calculate to be exactly the same diameter as the stock tires.. Tougher to find a performance tire in this size, however.
I am running 195/65/15s. My speedometer is optimistic due to the smaller than stock diameter tires, but I liked the look and the tire selection the best and have mentally adjusted for the speedo error by calibrating with my GPS.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-20876-1580603482.1.jpg)
You should also consider your ride height. My car is a little lower than stock. Ride height will make a difference in the "look" with each tire size considered.
BENBRO02
post Feb 1 2020, 07:54 PM
I run 205/55/15s on the 4 lug Fuchs. I had trouble finding performance rubber in 60 series. I didn't want all season tires because the rubber is too hard. The speedometer reads high but I have better acceleration with the 55s. I previously had 205/50/15s and the ride was too rough.Attached Image
- Lo-Fi Version Time is now: 8th February 2025 - 01:40 PM
