michelko |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None ![]() |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,400 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
The trim pieces mount/slide onto another metal trim part that's under the basketweave material. If you look at the backside of your column trim you will see where it would slide into. I have some pics let me see if I can find them.
Here's a thread to look over. http://www.914world.com/bbs2/index.php?sho...062&st=1000 |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,110 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
luke hit it on the money, and of course the 914-6 dash face metal is a different shape than both the 70-71 four cylinder, and the 72-74 four cylinder, so you MUST have the specific dash face for the "C" trim to work
The trim pieces mount/slide onto another metal trim part that's under the basketweave material. If you look at the backside of your column trim you will see where it would slide into. I have some pics let me see if I can find them. Here's a thread to look over. http://www.914world.com/bbs2/index.php?sho...062&st=1000 |
michelko |
Hi and Thanks for your Replys.
I am a Little confused abaout that Little grove on the inner side. I expected it on the outside so it coult slip ober the sheet metal. Michael ![]() Attached thumbnail(s) ![]() |
Luke M |
That's the groove I'm talking about. It slips into the metal portion of the 914-6 dash
tins. Check the link I posted and you can see where that groove goes on the tin. That's the only thing holding it in place. |
michelko |
That's the groove I'm talking about. It slips into the metal portion of the 914-6 dash tins. Check the link I posted and you can see where that groove goes on the tin. That's the only thing holding it in place. Hi Luke, now i found the solution. Thanks for the link. Michael |
Lo-Fi Version | Time is now: 27th December 2024 - 12:38 PM |
