Nose cone question, easy to R&R? |
Mueller |
Feb 10 2020, 10:47 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
On my sids shifter I would like to remove the rear cover to do a slight modification.
1. Is it a straight remove and replace job? 2. Do I have to worry about gasket thickness like other gaskets in the transmission? 3. It is magnesium correct? |
mepstein |
Feb 10 2020, 10:59 AM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
On my sids shifter I would like to remove the rear cover to do a slight modification. 1. Is it a straight remove and replace job? yes. you do have to keep the gear that sits inside the rear cover in place when you lift off the cover. If it falls on the floor, just make sure to put it back before you close up the case. 2. Do I have to worry about gasket thickness like other gaskets in the transmission? no 3. It is magnesium correct? yes |
Mueller |
Feb 10 2020, 11:42 AM
thanks!
Tdskip |
Feb 10 2020, 01:06 PM
Advanced Member Group: Members Posts: 3,702 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
One tip, that I have not tired, is a bit of grease to hold the gears in place when reassembling. It can be a bit fiddly otherwise.
Get other confirmation before doing that in case I am wrong. As @mepstein said, get ready to catch what will want to fall out. |
Lo-Fi Version | Time is now: 27th December 2024 - 08:36 AM |
