1.8 ignition harness |
Rikyrat |
Feb 13 2020, 04:46 PM
Member Group: Members Posts: 58 Joined: 30-January 19 From: Phoenix Member No.: 22,844 Region Association: None |
Help, I am so confused, so what is new.
What I am puzzled about, is 9 pin relay plug on the ignition harness. I do not remember taking it out, when I disassembled it, I don't remember it being there, everything was placed in a separate bag. I have looked at pictures of the harnesses that Jeff Bowlsby makes and there is no place for a relay on it But his ignition harness diagram shows it and the pinouts. Whats up with that? Is it needed? If so, what is the part number for the relay. I have the Bosch relay kit, which was in place when I removed the harness. Does that replace it? If anybody can shed some light on this I would be ecstatic. Thanks in advanced |
JeffBowlsby |
Feb 13 2020, 07:31 PM
914 Wiring Harnesses Group: Members Posts: 8,781 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hi RR,
The 1.8L ignition harness is much diff than the Djet ign harness. It does require a big square plug that connects to the dual relay. The 2wire big red cable to the battery is also in that plug. The other half of the dual relay connects to a plug-in the Ljet FI harness. I do not show photos of every harness I make But I do make Allred’s vine bay harnesses for each model year 914. There actually is aN NOS 1.8L Ignition harness photo down in the NOS harness gallery. Factory new that dual relay connector housing was not part of the harness, it has a separate part number. |
Rikyrat |
Feb 17 2020, 11:23 AM
Hi RR, The 1.8L ignition harness is much diff than the Djet ign harness. It does require a big square plug that connects to the dual relay. The 2wire big red cable to the battery is also in that plug. The other half of the dual relay connects to a plug-in the Ljet FI harness. I do not show photos of every harness I make But I do make Allred’s vine bay harnesses for each model year 914. There actually is aN NOS 1.8L Ignition harness photo down in the NOS harness gallery. Factory new that dual relay connector housing was not part of the harness, it has a separate part number. Thanks Jeff Where do I find the part number for the relay. I have checked everywhere and can't seem to find one. |
JeffBowlsby |
Feb 17 2020, 01:12 PM
0332514129
Attached image(s) |
Lo-Fi Version | Time is now: 26th December 2024 - 08:50 PM |
