rocker shaft blocks, tell them apart? |
brer |
Jul 6 2005, 03:22 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
I just read that the rocker assembly blocks are not symmetrical.
How do you tell them apart? and if they are different, which ones go where? |
Jake Raby |
Jul 6 2005, 03:39 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
They are symmetrical... They can be inverted any way you like, BUT the proper way is with the groove down.
The rocker SHAFTS only install one way, but not the blocks. This is due to a chamfered edge under to match the taper of the rocker stud. |
914werke |
Jul 6 2005, 03:51 PM
"I got blisters on me fingers" Group: Members Posts: 11,038 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
need visual (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Are you refering to the Solid spacers that replace the OE springs in the Shafts? |
brer |
Jul 6 2005, 03:54 PM
thats good. One less thing to check for when i pull it apart again. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
must have interpreted that other post wrong. thanks, b. |
MattR |
Jul 6 2005, 04:45 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
I wrote that they arent symmetical. I meant the blocks have a proper orientation: the groove must be downward (for the retaining wire) and the bevel must be facing outward. When you take off the blocks, you'll see the part of the block facing outward has a slight bevel to it, as opposed to the part that makes contact with the head, which has a straight edge.
Lo-Fi Version | Time is now: 4th January 2025 - 11:08 PM |
