Transmission 5th gear, Grinding going into 5th |
Ampex351 |
Apr 9 2020, 10:36 PM
Member Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest |
The the transmission on my '73 shifts nicely through all gears except 5th. What the heck would cause 5th to grind? linkage need adjustment? Time for a rebuild?
What? Where do I start? |
billh1963 |
Apr 10 2020, 04:28 AM
Car Hoarder! Group: Members Posts: 3,403 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Start with checking/replacing all the shift bushings and adjustment
BeatNavy |
Apr 10 2020, 05:05 AM
Certified Professional Scapegoat Group: Members Posts: 2,933 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Start with checking/replacing all the shift bushings and adjustment (IMG:style_emoticons/default/agree.gif) You have to do this methodically. First, make sure all bushings and linkages are functional and properly installed. Then you need to make sure everything is adjusted within it's proper range. Lots of threads on this out there. Here are a couple: Bushing replacement, in general: http://www.914world.com/specs/fwsb_replace.php Shift linkage adjustment: http://www.914world.com/bbs2/index.php?showtopic=188120 another, http://www.914world.com/bbs2/index.php?showtopic=91028 Use whatever procedure (Dr. Evil's, or Chris') works for you. Reading through them helps understand how everything is supposed to work. Only after checking all that should you consider tearing into the gearbox. |
ctc911ctc |
Apr 10 2020, 07:09 AM
Senior Member Group: Members Posts: 917 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Start with checking/replacing all the shift bushings and adjustment (IMG:style_emoticons/default/agree.gif) You have to do this methodically. First, make sure all bushings and linkages are functional and properly installed. Then you need to make sure everything is adjusted within it's proper range. Lots of threads on this out there. Here are a couple: Bushing replacement, in general: http://www.914world.com/specs/fwsb_replace.php Shift linkage adjustment: http://www.914world.com/bbs2/index.php?showtopic=188120 another, http://www.914world.com/bbs2/index.php?showtopic=91028 Use whatever procedure (Dr. Evil's, or Chris') works for you. Reading through them helps understand how everything is supposed to work. Only after checking all that should you consider tearing into the gearbox. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) I would add that a GOTCHA in the linkage is the midpoint Conical-Bolt. This one is very tricky, torque, jostle, torque, jostle, torque, jostle, torque until you are sure the two parts are solid and the Bolt is seated, small movement within this part of the linkage is a very frustrating bug in the system. Might lead to a tranny tear down when you do not need one. Ask me how I know. |
Lo-Fi Version | Time is now: 26th September 2024 - 11:57 AM |
