914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
What is the correct torque value for this bolt (the upper strut nut, or whatever it's actually called):
![]() The Haynes manual is not clear and the one post I could find on this site just reprinted what that said. |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
I did on few 914s and twice on my running car before was by feel only to tighten it. Old style. So far I had no issues.
914 RZ-1 |
It's 58 lb-ft. I found it in another post.
It's called a "nut" in the Haynes manual exploded view and the description and there's a reference to a "suspension strut/support bracket" in the torque specs. The "support bracket is referred as a "strut support", and "supporting bearing (I think)" in other places in the manual and I've seen it referenced as a "top front strut support nut" and "strut retainer nut" other places. Hence my confusion. I didn't go with "hand tight" because I could have over-tightened it with the breaker bar or not tightened it enough with my wrench. I figure they give torque specs for a reason. I hope this is useful to anyone else searching for this. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
What is the correct torque value for this bolt (the upper strut nut, or whatever it's actually called): ![]() The Haynes manual is not clear and the one post I could find on this site just reprinted what that said. Did you bent up the lock tab to prevent the nut from backing off ? That its function. Looks like most of the nyloc material extruded out on yours. Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 01:22 AM |
