Engine cooling rubber around tin, need to know if it's all the same |
Mikey914 |
Jul 6 2005, 09:35 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Went to Halsey Imports to buy new engine rubber as I had a fire and it's all toast. They sent me a 4' piece that I can only assume is the front or rear. They do not have a clue.
My question is this: Is it all the same, so that I could just order 2 more pieces and cut one for the sides? Or is ther eanother profile for the sides and or front/ back. Would appreciate any info. Thanks |
Dave_Darling |
Jul 6 2005, 10:22 PM
914 Idiot Group: Members Posts: 15,065 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The front piece is the same profile as the side pieces. The side pieces are shorter, naturally. Sadly, the side pieces are more than half the length of the front one, so you can't just buy two fronts and cut one in half. You'd need to buy three fronts and cut two of them down.
The rear piece has a totally different profile. --DD |
Lo-Fi Version | Time is now: 30th December 2024 - 11:25 AM |
