Jim C |
Member ![]() ![]() Group: Members Posts: 195 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region ![]() ![]() |
I do not have a heater and am trying to block off the ducts leading into the car. Will the factory plastic passenger J pipe block off caps work for this purpose? Does anyone have any ideas or know off hand what size pipe caps might work?
Coondog |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California ![]() ![]() |
914Toy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 722 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California ![]() ![]() |
Hardware store - 2" black plastic pipe cap.
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
Top Secret.
Spray paint can top. Soft enough to use a clamp. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
DickSteinkamp |
Senior Member ![]() ![]() ![]() Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None ![]() |
Block off the tubes in the longs at the firewall end with 2" pipe caps. Perfect fit and they even come with the clamp.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images-na.ssl-images-amazon.com-20876-1587049628.1.jpg) Block off the inlets to the cabin with MadDog's kit... ![]() Heater block off kit |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
I used heat shrink caps. (IMG:style_emoticons/default/smile.gif)
https://www.mcmaster.com/heat-shrink-end-caps |
Jim C |
Thanks all!
SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,612 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
Yep- spray can top and you can get it in many colours!!
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Soda can bottom a black RTV bead around the edge and stick it on. You might need temporary tape if holding it up.
We call them pop cans, you could use a beer can bottom and paint it black beforehand. I've done this for years, looks good, fast, stays put, easily reversible and damn better than a hole. |
sb914 |
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,323 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California ![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 11:07 PM |
