mtc911 |
Member ![]() ![]() Group: Members Posts: 65 Joined: 18-March 18 From: Atlanta Member No.: 21,978 Region Association: South East States ![]() |
So, I have researched this one quite a bit and i cant seem to find the right answer. I have a “built” 2056 with Dual Weber Carbs. I “believe” it is a 1.7 Case with 2.0 Heads on it - not 100% sure there but the engine number seems to indicate that.
Anyway I have (2) the little Crankcase Breather Filters - one on the driver side and one on the oil fill (seen in the pictures). However there is nothing on the passenger side head. On the drivers side there is a T/splitter type thing that also pulls in a port out of the fan shroud. Obviously these little filters are making an oily mess in the engine bay - nothing too tragic but i would like to get rid of it if possible. I have been looking at the little Cans by Empi and Scat - that look like they would work. But I’m still kind of confused. 1 - Why would I have one of these on the Driver side Head and not the passenger side? 2 - If i install one of those cans should i route the port off of the fan shroud into it? I have read both yes and no on that question in my research. 3 - Will the can really even help reduce the oil in the bay? I have read yes and no on that question too 4- attached diagram is what i was planning to do with the breather box - is this correct? 5 - is there any downside to using one of these instead of the little cheaply filters? I have read a ton of posts on this in various forums and I cant come to a conclusion. Yet. Thanks ![]() ![]() ![]() ![]() |
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
I would start with removing the tube connected to the fan shroud. That is the air output for the carbon cannister and should not be connected to the crank case breathing system. Its most likely a big part of your oily mess since it takes fan air pressure and helps to push oily air out thru the little filters.
Do you not have a port at all on your passenger side head? Thats a bit wierd, maybe the heads are from different years? If you still want to do the catch can thing I would want to connect both heads and the oil filler tower. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
The EMPI breather boxes are crap.
You need a sealed box; -hose on the bottom drains back into the case or puke bottle. -hose in the middle is from the case breather tower. -hose in the top to a carb. I'd just plug the head vent. On my bug I used a EMPI breather box but I milled off the lid tit's and sealed the box with sealant. I remove the foam and bend up the metal screen so that it catches vapours. I then mounted it vertically with the now bottom draining back to the case and top vented to a carb. I drill extra vent holes in the middle and use breather vents. |
mtc911 |
I would start with removing the tube connected to the fan shroud. That is the air output for the carbon cannister and should not be connected to the crank case breathing system. Its most likely a big part of your oily mess since it takes fan air pressure and helps to push oily air out thru the little filters. Do you not have a port at all on your passenger side head? Thats a bit wierd, maybe the heads are from different years? If you still want to do the catch can thing I would want to connect both heads and the oil filler tower. When you say “remove it” you man just leave it open or plug it with something. Seems like you would want that fan shroud port plugged, no? |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,642 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I would start with removing the tube connected to the fan shroud. That is the air output for the carbon cannister and should not be connected to the crank case breathing system. Its most likely a big part of your oily mess since it takes fan air pressure and helps to push oily air out thru the little filters. Do you not have a port at all on your passenger side head? Thats a bit wierd, maybe the heads are from different years? If you still want to do the catch can thing I would want to connect both heads and the oil filler tower. When you say “remove it” you man just leave it open or plug it with something. Seems like you would want that fan shroud port plugged, no? you can plug it its going to be a small amount of clean air... being pushed by the fan it will hurt nothing to leave it unplugged... its just positive pressure air but the crank case is also expelling positive pressure thus the reason you do not want those two connected together the fan air is pushing the crank case pressure back into the case the opposite of how a crank case breather is supposed to work probably that lack of released pressure can just come out another breather on the motor but ultimately, the lack of a proper crank case breathing system creates leaks and other problems. disconnect it |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Hoffman Automotive Machine (HAM) has a good article about venting on their website. This may help.
https://newsite.hamheads.com/2016/12/10/typ...tests-analysis/ |
mtc911 |
So, since the head vent was already there and i was getting kinda oily mess in the engine compartment..i bought this cheapy canister thing...vented one head (because the other one isn’t? Which is still kinda odd - and just ran a T of the oil fill tower...just to use all 3 ports...test drive showed no oil blowing out around the oil fill - or anywhere else...didn’t notice any change in oil pressures or anything...it was a cheap way to test it out...and with nothing better to do since we’re not supposed to leave the house...heck ,it was something to do
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
I interconnected the head vents together (somewhere heard Jake recommended that) and used a low height vent canister with one vent to air filter and bottom to oil fill chimney. This sits high enough to insure draining to the chimney.
I get no oil staining into the flex hose to the air filter and everything stays clean. 2 extra ports on top left capped. ![]() |
Lo-Fi Version | Time is now: 20th June 2024 - 11:17 PM |
