> How to wire up an early 911 turn signal switch into a 914-4 harness, For MB911 - Your 12 step program.
ClayPerrine
post May 8 2020, 03:00 PM
Step 1. Buy these:
1980 Porsche 911SC Female Housing, 14 Pin
1983 Porsche 911SC Pin, Female 14 Pin Connector (you need 14 of these)
1969 Porsche 911 Lid, 14 Pin Plug
1969 Porsche 911 14 Pin Plug Male Kit
Why Porsche chose to provide a kit for the Male plug, but make you purchase all of the pieces for the female connector separately we will never know.
2. Remove the connectors from the ends of the wires on the turn signal switch. Don't remove the one on the switch end Brown/White wire. That connects to the back of the horn wiper ring.
3. Strip the insulation off the wires, and solder on the pins for the MALE connector. You don't want to use the female end, because some of those wires can be hot with 12v if you use the male connector on the chassis harness side.
4. Put the pins into the bottom of the male connector. Make notes of the wire color associated with each pin number.
5. Install the top on the connector.
6. Remove the beam relay and disconnect the wires. There is a large yellow wire and a small yellow wire. Strip and solder on female pins to the large yellow, white and red/white wires. The small yellow wire is not going to be used.
7. Remove the plug that connects to the turn signal/wiper switches. The wires that connected to the wiper switch are not going to be used any more.
Note: I like to take the time to completely remove the wires from the harness, but it is OK to leave them there. Just tape them off so they don't short anything.
8. Strip and solder the remaining female pins onto the brown/white, black/white, black/white/green, black/green, grey/red, grey/brown, grey, and red.white wires.
9. Install the female pins into the female connector base. Make sure you match the connections with the wires in the male connector. I like to put the female base on the male connector and install the pins to match.
10. Install the cover on the female connector.
11. Test the wiring. Make sure the turn signals work, the low and high beams work and make sure the park light lights on one side with the key off and the turn signal engaged.
12. Last and most important step. Have a beer and celebrate!
Here is a chart of the wire connections for your reference.
Replies(1 - 19)
mb911
post May 8 2020, 03:48 PM
Thanks so much.. Its on order.. Still have to figure out wiper switch but that is likely more direct
ClayPerrine
post May 8 2020, 05:22 PM
QUOTE(mb911 @ May 8 2020, 04:48 PM) *
Early 911/914-6. No connections inside the car. the end of the wiring terminates in what looks like a relay socket mounted in the front wall. The wiper motor has a plug to match. Only two wires to connect, power and ground.
ClayPerrine
post May 8 2020, 05:23 PM
And if you run into any problems with the wiring, let me know.
Clay
mb911
post May 8 2020, 05:35 PM
Sounds good.. Thanks
GregAmy
post May 9 2020, 10:52 AM
What's the advantage of the 911 one?
mb911
post May 9 2020, 10:55 AM
QUOTE(GregAmy @ May 9 2020, 08:52 AM) *
Left hand ignition setup.
mb911
post May 10 2020, 01:37 PM
@ClayPerrine my beam relay has a yellow with Red tracer (small) would that be the same as the small yellow? I am assuming so..
ClayPerrine
post May 10 2020, 07:00 PM
QUOTE(mb911 @ May 10 2020, 02:37 PM) *
Yes. That is unused with the 911 switch. It goes from the /4 turn signal switch to the relay to make the relay change from low to high beams.
mb911
post May 13 2020, 07:20 PM
So this bundle of wires won't get used? Attached Image
ClayPerrine
post May 14 2020, 07:40 AM
QUOTE(mb911 @ May 13 2020, 08:20 PM) *
Nope.. Those are all for the wiper switch. The 914-6 wiper switch has a completely different connection.
The wiper switch has a connection that matches this:
It fits into the round hole behind the insturment cluster, and is connected to the spade connectors on the wiper switch. One lead will go to 12v+ and one will go to ground.
You can scavenge the connector off of an old harness or buy one new. I would get a new one.
Clay
mb911
post May 14 2020, 01:32 PM
This is harness side and must have plugged into the wiper switch prior?
ClayPerrine
post May 15 2020, 12:14 PM
QUOTE(mb911 @ May 14 2020, 02:32 PM) *
Yes. The 911 or 914/6 wiper switches will already have the connector that fits this on the wires.
post May 15 2020, 01:57 PM
914-6 GT in waiting
Thank you Clay (IMG:style_emoticons/default/beerchug.gif)
mb911
post May 16 2020, 06:08 PM
Ok done and done meaning soldered ends, had a beer.. Now I have no headlights except when I pull the lever as if to pass someone.. There are no turn signals either.. I did determine I have no power to the large yellow wire on the harness.. If I jumper 12v to that I get headlights then go on..
mb911
post May 16 2020, 08:35 PM
Well plot thickens.. Found out the yellow wire was not hot because it is only getting 12v when the ignition switch is turned to start. Will work on that tomorrow
mb911
post May 17 2020, 01:45 PM
Problem semi solved.. Was not getting 12v to the yellow wire for the headlights because of the 911 ignition switch.. I have that solved.. I do not have blinkers or high beams but I have flashers which is odd.
ClayPerrine
post May 18 2020, 04:38 AM
Ben,
I haven't forgotten about you. I spent the weekend in the garage fixing a BMW motor for our 540i.
I will get back to you later today on next troubleshooting steps.
Clay
ClayPerrine
post May 20 2020, 06:54 PM
Ben,
Do you have low beams?
Do you have park lights?
PM me for my phone number and we can work with it on Saturday.
Clay
Mark Henry
post May 20 2020, 09:25 PM
that's what I do!
Thanks Clay bookmarked this thread.
I think I have the harnesses for the turn and wiper switches, but I'm missing the big round connector for the ignition switch I have.
- Lo-Fi Version Time is now: 19th April 2025 - 06:25 PM
