> Fuel Pump Issues - SOLVED?
BPic
post May 16 2020, 06:23 PM
A little background first.
This car is a 72 full rebuild and I bought the engine with carbs from a member. I re-worked the entire harness and everything is working fine with the exception of the fuel pump that was relocated up front.
It worked great and always came on with the key and then it didn't. I pulled the tank checked the power and I have 12 + volts if grounded to the chassis but not with the ground at the pump. I did the grounding mod at the relay board to use the fuel pump relay based on Sir Andy's post. I'm using 914Rubbers new relays.
When it first quit, after checking the voltage I swapped a new relay in and it worked. Then it quit again so I tried several other new relay without any luck. You can hear the relay click so it appears to work. Also when I turn on the hazards that is the relay that clicks on and off with the flashers, I thought this was odd, am I wrong? (IMG:style_emoticons/default/confused24.gif)
What else do I need to check? I'm frustrated as I was getting ready to start the car for the first time in 2.5 years.
Thanks all! I would appreciate any and all advise. So I can get this thing started. (IMG:style_emoticons/default/beerchug.gif)
Replies(1 - 5)
BPic
post May 17 2020, 07:31 AM
I went to ground at the headlight and pump is now operational.
ndfrigi
post May 17 2020, 10:23 AM
Thanks for sharing and good job fixing it yourself!
Superhawk996
post May 17 2020, 10:42 AM
Let's hear / see it running. Post success to YouTube and embed it here!
BPic
post May 17 2020, 02:36 PM
QUOTE(Superhawk996 @ May 17 2020, 12:42 PM) *
Here you go @superhawk996
I did a new thread for it as well. But since you asked.
https://youtu.be/8d6uRwdJL_w
Superhawk996
post May 17 2020, 02:40 PM
QUOTE(BPic @ May 17 2020, 04:36 PM) *
What an awsome sound. Combination on intake and ticking tappets and exaust. I love air cooled engines!
Thanks for posting.
That must feel awesome to have it firing.
- Lo-Fi Version Time is now: 26th December 2024 - 06:57 AM
