Chassis stiffening using the front and rear trunk |
porschecb |
Jul 10 2005, 01:14 PM
Senior Member Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
Hey, i was wondering if there were any after-market parts to stiffen the chassis or is my best bet to go to a fab shop? thanks.
ArtechnikA |
Jul 10 2005, 01:28 PM
yes, there are several excellent chassis strenghtening / stiffening / reinforcement parts available; check the resourcs section. in particular, there are kits for the inner and outer longitudinals that really help a lot.
but your front or rear trunk would be used only to transport the parts. you can stiffen the trunks all you like but it will make no difference - the chassis does not flex there. the only significant flex is in the cabin area. |
anthony |
Jul 10 2005, 02:18 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
SpecialK |
Jul 10 2005, 03:32 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
So what are the shock tower (cambermeister?) bars for? |
ArtechnikA |
Jul 10 2005, 03:44 PM
911's. you don't need one in the front (unless you have a GT with a 100-liter tank, in which case your car should have come with one...). the tank bulkhead provides all the stiffness you'll need until you go to coilovers, at which time you'll need way more than a strut brace. you don't need one in the back because the strut mounts are not kinematic points. they're just a place the springs and dampers work against. 911's really need some triangulation, but for 914's they're just expensive froo-froo. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:31 PM |
