forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
Can anyone let me know if there is specific hub set for the rear of an original 914-6 (verses 911) and/or how do I clearly represent what was sold to me as "914-6 rear hubs"
as just that at the point of listing herein? The number 901 33J ... ... is on both hubs Also, any estimate of value for the pair?Thanks to all. (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) ![]() ![]() |
aturboman |
Member ![]() ![]() Group: Members Posts: 136 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None ![]() |
The rear hubs are the same as 911 and are a 901 part number in the parts book.
The stub axles however that go into the hubs are 914-6 specific (only) and are quite hard to come by. Hope this helps |
forrestkhaag |
The rear hubs are the same as 911 and are a 901 part number in the parts book. The stub axles however that go into the hubs are 914-6 specific (only) and are quite hard to come by. Hope this helps yes it does / thanks (IMG:style_emoticons/default/beerchug.gif) |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
69 on 911 stub axles will fit with the larger 100mm or 110mm CV joint
Lo-Fi Version | Time is now: 20th June 2024 - 06:29 AM |
