Jett |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,646 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest ![]() ![]() |
Looking for any guidance on correct paint, potential deconstruction techniques, etc.
Thanks |
Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
I restored mine. The top (the silver cap) has to come off. You just have to pry the small tabs to get it off. Then the whole screw mechanism comes off. You also will need to remove the green cap off of the handle if you’re going to paint that item. I had the handle and body powder coated low gloss black. I sanded the silver cap and then had it replayed along with some other items (seat base arms, etc.). The jacks look fantastic when they’re done.
Jett |
I restored mine. The top (the silver cap) has to come off. You just have to pry the small tabs to get it off. Then the whole screw mechanism comes off. You also will need to remove the green cap off of the handle if you’re going to paint that item. I had the handle and body powder coated low gloss black. I sanded the silver cap and then had it replayed along with some other items (seat base arms, etc.). The jacks look fantastic when they’re done. Thanks, I have a few so will give it a try. |
Lo-Fi Version | Time is now: 24th June 2024 - 05:52 AM |
