Headlamps, Headlamps cycle continually |
Steve91486310 |
Jul 26 2020, 03:17 AM
Newbie Group: Members Posts: 3 Joined: 26-July 20 From: France Member No.: 24,533 Region Association: France |
Hi everybody. 914-4, 1973 model, I have a problem with my headlamps, (with the ignition switch off) they continually cycling up and down when the headlamp switch is in the "OFF" position, they work just fine when the headlamp switch is pulled out "ON", has anybody any ideas please. Cheers.
Dion |
Jul 26 2020, 08:08 AM
RN Group: Members Posts: 2,793 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
I had a similar problem one time. Except the lights would alternately go up and down
L then R. Like a dance! Not sure how it works , not an electrical expert, but I replaced one of the relays that is mounted at the headlite Itself. Worked for me. Just an idea. Check all the relays and grounds. Clean them. Then begin testing for continuity. Someone with more expertise will chime in. Attached image(s) |
Steve91486310 |
Jul 26 2020, 08:12 AM
Many thanks, thats a good starting point. Cheers.
theer |
Jul 26 2020, 08:28 PM
Senior Member Group: Members Posts: 681 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Check the Relay... or the switch itself, if both are doing it in tandem. |
Steve91486310 |
Oct 23 2020, 01:19 AM
(IMG:style_emoticons/default/agree.gif) Check the Relay... or the switch itself, if both are doing it in tandem. Thanks Tom H, appreciated |
Lo-Fi Version | Time is now: 22nd September 2024 - 12:08 PM |
