IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Looking for the gummi O ring for the front grease cap on 4 cyl, it's NLA
Factory part number is 421 839 455 I'm trying to get 914Rubber to reproduce this part, would you buy some if available? Attached image(s) ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@IronHillRestorations
I never knew one was there. Have you searched for a common o-ring replacement? |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
That O ring looks like its for the 914/6 front grease cap not a 4 cyl model.
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
All VW products had one in the 1970s, most were never replaced when removed.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
All VW products had one in the 1970s, most were never replaced when removed. (IMG:style_emoticons/default/agree.gif) often overlooked. But it's a pretty generic use. Something "in the ballpark" should be fine. |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Mc Master Carr carries all kinds of O-Rings, should be able to find one close enough
Nacho |
Member ![]() ![]() Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None ![]() ![]() |
Mc Master Carr carries all kinds of O-Rings, should be able to find one close enough (IMG:style_emoticons/default/agree.gif) |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Its not a standard rubber o ring. Thats qhy im looking at doibg these.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
It iwas never on a 6 or a 911 It is not a standard type O ring, it's soft , foam-like. As seen in the photo it has a glued seam, made from running material. |
Mikey914 |
We can make a as a unglued piece or same way pretty inexpensively.
bdstone914 |
Mc Master Carr carries all kinds of O-Rings, should be able to find one close enough (IMG:style_emoticons/default/agree.gif) I found this flat one that looks like it will work. Attached thumbnail(s) ![]() |
Mikey914 |
Actually looking for an original. We plan to replicate or improve the design. Oil based greases will attack rubber. Viton is most likely the best option.
GeorgeKopf |
Member ![]() ![]() Group: Members Posts: 172 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region ![]() |
Any movement on this? My hub seals fell apart when I pulled off the hubs.
I'm thinking that part number: 2418T199 on McMaster-Car, might be perfect. Soft Rubber Oil Resistant 48mm = 1 7/8 inner diameter 3/16" thick Round profile Thanks. George |
Lo-Fi Version | Time is now: 25th June 2024 - 07:56 PM |
