MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
Kinda says it all.
Any available somewhere? Item #30 in the attachment. Attached image(s) ![]() |
Fosterjoejr |
Newbie ![]() Group: Members Posts: 1 Joined: 30-December 15 From: Dallas Texas Member No.: 19,502 Region Association: Southwest Region ![]() ![]() |
Kinda says it all. Any available somewhere? Item #30 in the attachment. 914 Rubber has this. https://914rubber.com/search/?q=grommet%20B021119553 |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Pretty sure I have some factory grommets. I’m traveling today and I’ll get back to you
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Kinda says it all. Any available somewhere? Item #30 in the attachment. 914 Rubber has this. https://914rubber.com/search/?q=grommet%20B021119553 They do not show a part that matches that part number. Your search looks for all grommets. The only one that looks close is this which is described as 24mm rubber sleeve. the CHT hole is 26mm. Attached thumbnail(s) ![]() |
MartyYeoman |
adolimpio |
Art ![]() ![]() Group: Members Posts: 182 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States ![]() ![]() |
Amazon has an assortment of solid grommets that allow you to add whatever hole that you need. That's where I got my CHT grommet, and numerous others.
See:Amazon grommets |
Robarabian |
914 A Roo ![]() ![]() ![]() Group: Members Posts: 593 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California ![]() ![]() |
Go to Harbor Freight and buy the Grommet Kit. I took one that fit the main hole well, and then fit a second grommet in the hole of the first one. Seals tight and has a small hole for the wire to pass through. Bonus: You get lots of other grommets and its like 4 bucks. If you really want it to hold, you can do a little gluing / black RTV one grommet in another. It was an easy fix.
Sorry it’ll be Friday. Changed plans due to weather
bdstone914 |
Kinda says it all. Any available somewhere? Item #30 in the attachment. 914 Rubber has this. https://914rubber.com/search/?q=grommet%20B021119553 Your search looks for all grommets. The only one that looks close is this which is described as 24mm rubber sleeve. the CHT hole is 26mm. Edit. I had an OEM Porsche gromett that had the same referance number as the 914 Rubber part. It fits in the hole with some slop but looks like it is will work ok. |
MartyYeoman |
Amazon has an assortment of solid grommets that allow you to add whatever hole that you need. That's where I got my CHT grommet, and numerous others. See:Amazon grommets Thanks for the Amazon hookup. (IMG:style_emoticons/default/smilie_pokal.gif) |
JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,933 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
When looking for parts, always remember you are driving a Volkswagen (IMG:style_emoticons/default/smile.gif)
https://www.busdepot.com/021119553 |
Archie |
Member ![]() ![]() Group: Members Posts: 197 Joined: 23-September 09 From: Western Canada Member No.: 10,844 Region Association: Pacific Northwest ![]() |
When looking for parts, always remember you are driving a Volkswagen :) https://www.busdepot.com/021119553 Excellent advice! |
bdstone914 |
When looking for parts, always remember you are driving a Volkswagen (IMG:style_emoticons/default/smile.gif) https://www.busdepot.com/021119553 @MartyYeoman If you do order that gromett olease report back if it is actually available. It is said to be genuine and special order. Or call a VW dealer and ask them. I know that sometimes the same part that may be discontinued by Porsche is available from VW. That Amazon assortment has a 25.4 mm gromett that should work in the 26mm hole. |
MartyYeoman |
When looking for parts, always remember you are driving a Volkswagen (IMG:style_emoticons/default/smile.gif) https://www.busdepot.com/021119553 @MartyYeoman If you do order that gromett olease report back if it is actually available. It is said to be genuine and special order. Or call a VW dealer and ask them. I know that sometimes the same part that may be discontinued by Porsche is available from VW. That Amazon assortment has a 25.4 mm gromett that should work in the 26mm hole. I went with the Amazon grommet set. |
Arno914 |
Member ![]() ![]() Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany ![]() ![]() |
QUOTE When looking for parts, always remember you are driving a Volkswagen smile.gif VW Classic has them (at least in Germany). Got mine today (incl. one spare, you never know...25 years from now…) (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1628782650.1.jpg) |
Lo-Fi Version | Time is now: 26th June 2024 - 04:54 AM |
