BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 550 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
I know that early D-Jet Manifold Pressure Sensors (MPS) were riveted together. At some point, did Bosch change over to using screws instead of rivets? If so, about when did that happen? I found pictures of both, but nothing on if/when the change occurred.
I tried searching for the answer here, but wasn't able to find anything. Thanks! |
JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,933 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
AFAIK screws are a sign that an MPS have been opened.
If rebuilding one, not sure I would trust rivets to hold a good seal. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I know that early D-Jet Manifold Pressure Sensors (MPS) were riveted together. At some point, did Bosch change over to using screws instead of rivets? If so, about when did that happen? I found pictures of both, but nothing on if/when the change occurred. I tried searching for the answer here, but wasn't able to find anything. Thanks! I have about 20 of them and can check it any eraly had screws or rivets. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
They came BOTH ways from the Bosch factory. My guess is they swapped over to screws to make it easy to repair them. NO time frame for when this happened.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 12:45 AM |
