rear bearings |
rear bearings |
Bruce Hinds |
Feb 16 2021, 10:35 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Any tips and or tricks for replacing the rear wheel bearings without removing the trailing arms?
mepstein |
Feb 16 2021, 10:52 PM
914-6 GT in waiting Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
PMB has a video on their site.
Bruce Hinds |
Feb 16 2021, 11:44 PM
cary |
Feb 17 2021, 12:12 AM
I have an old tool kinda like this one.
https://www.paragon-products.com/Porsche-Wh...-p/awx-bt-2.htm |
ndfrigi |
Feb 17 2021, 12:26 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
https://youtu.be/lnXdjTate5o
https://youtu.be/FDZv0j85Ybc https://youtu.be/3sfC1NiXamA If you will need alignment, I think it is better to just remove the suspension arm. Easy to remove the bearing and safer. |
Bruce Hinds |
Feb 17 2021, 08:16 AM
Thanks for the links guys
bbrock |
Feb 17 2021, 09:16 AM
You can rent a slide hammer hub puller from Autozone (and probably other FLAPS) for free that makes pulling that hub a breeze. i think pulling the hub is easier done with the trailing arm on the car myself.
I have a Harbor Freight Front Drive Wheel Bearing Removal kit that worked great for removing and installing the bearing. Again, I think just as easy on the car as off. Unfortunately it looks like the price of that kit has gone up quite a bit since I bought mine but I've used it on both my 914 and our Honda CRV DD so it has easily paid for itself. |
forrestkhaag |
Feb 17 2021, 09:17 AM
Freeze the Fag bearings overnight then have a can of aerosol keyboard cleaner handy when installing. Flip the can upside down and empty half on each bearing - the gas comes out as a sub zero stream that will reduce the mass of the bearing enough to slide it into the race without much pounding. Do this in Texas today and you can skip the freezer part.......... (IMG:style_emoticons/default/hissyfit.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:41 AM |
