TRS63 |
Member ![]() ![]() Group: Members Posts: 316 Joined: 14-September 20 From: Germany - Stuttgart Member No.: 24,690 Region Association: Europe ![]() ![]() |
Hello together,
I am driving my 914 a lot (they were made for it!) and living in Germany and not in California, sometimes under water (IMG:style_emoticons/default/unsure.gif) It has received some preventive treatment on the underside during the previous ownership, but I would love to check that every drain holes are open and not clogged in order to avoid more issues on that side. Can anybody here tell me where they all are? Maybe on a drawing? Thanks in advance Antoine |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,993 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Bottom of doors
Bottom of jack point pyramid Bottom of rear suspension consoles (inside ear - closest to engine) Bottom of area under the gas tank. There are two here: 1) corrugated tube that drains from fresh air box 2) a slot in sheetmetal that drains the area under the gas tank. Bottom of the longitudinals have about two or three drain holes each side Look below door posts at front of door, there are stiffeners here that have a couple drains at bottom. Sort of count as checking the longitudinals but there are two drains on just these panels that attach to the exterior of the longitudinals. Those are the important ones that immediately come to mind for me. |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
The headlight buckets have large drain holes that plug easily with leaves or pine needle and both hell holes have a rubber vent that is guaranteed to drain slowly if at all.
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Front trunk floor too
You might also consider regularly checking locations that do not have drains, but should. Rear trunk floor Front trunk lid weatherstripping channels Front fenders to cowl seam Cockpit floor especially behind the seats |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,835 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Forward engine shelf corners (left and right hell holes) should have drain holes in the shelf (and some odd rubber drain stoppers, I think).
TRS63 |
Lo-Fi Version | Time is now: 26th June 2024 - 02:30 AM |
