McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
(IMG:http://www.universible.com/images/alfa/gtv/kaboom-07-16-05/IMG_2512.jpg)
That picture was taken from under the car. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) The Whole Thread |
ematulac |
914 addict ![]() ![]() ![]() Group: Members Posts: 540 Joined: 24-November 03 From: Palmdale, CA Member No.: 1,382 ![]() |
Insane damage. The bell housing on his tranny was literally blown apart! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
See
this is why we like alll this stuff behind us and not under you (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
Least we ain't got no doughnuts!
(check yer cv joint bolts - a completely unrelated observation) |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
when transmissions attack, next on FOX
that is jacked! |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,294 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
That will leave a mark. (on his wallet)
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
It wasn't the bellhousing that blew apart, it was aft of that. On most Alfas, rubber donut flex joints are used on the driveshafts. On the GTV, there's one connecting the output flange of the transmission to the driveshaft. There's a conventional U-joint connecting the driveshaft to the diff. You have to keep on top of these joints, and replace them roughly every 50K miles. If they split, you often get away with it and just suffer lots of vibration until you fix them. Sometimes, they fly apart, and this kind of thing happens. The damage was from the loose driveshaft flailing around. The Alfetta-based cars were much worse. They have a front engine/rear transaxle setup like a 924/944/928. There are THREE rubber donuts connecting the two-piece driveshaft from the engine to the gearbox, and the clutch is on the gearbox, not the engine. So, that driveshaft is spinning at engine speed the entire time the engine is running. The donuts are really hard to get at (you have to basically remove the gearbox to get the shaft out, which has to be done to get the donuts off), and shops charge $750-1000 to replace all three donuts. Every 40-50K miles. Or this kind of thing can happen. That said, I owned two Alfetta cars and put lots of miles on them with no worries. I just inspected the donuts regularly. I only had to replace them on one car once, and it took me three weekends to do it. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:46 AM |
