914 Steering Wheels |
Rob-O |
May 19 2021, 08:05 PM
Senior Member Group: Members Posts: 1,256 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Just a quick question. Did any of the factory 914 steering wheels come without ‘finger groves’? It seems like maybe the Momo Prototipo and modern Porsche models have steering wheels without them.
I’m considering having my steering wheel recovered. My wheel is the late model that looks like leather but is really just type of rubber/foam material. I’m not sure that material has to come off (or even what’s underneath) when the wheel is recovered. But if it does need to come off then maybe a wheel without ridges could be made. Any input is appreciated. |
bdstone914 |
May 19 2021, 09:13 PM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Just a quick question. Did any of the factory 914 steering wheels come without ‘finger groves’? It seems like maybe the Momo Prototipo and modern Porsche models have steering wheels without them. I’m considering having my steering wheel recovered. My wheel is the late model that looks like leather but is really just type of rubber/foam material. I’m not sure that material has to come off (or even what’s underneath) when the wheel is recovered. But if it does need to come off then maybe a wheel without ridges could be made. Any input is appreciated. To my knowledge they all had finger grooves. If you remove the foam you will have a steel ring about 10mm in diameter. You may bebetter off starting with a hard plastic wheel if you are covering it with leather. |
johnhora |
May 19 2021, 09:38 PM
Senior Member Group: Members Posts: 874 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Rob...it's a round steel rim under the rubber/plastic....I think I have a picture or maybe even a bare wheel....if your rubber material is not loose and twisting you can have it recovered.
Rob-O |
May 20 2021, 09:27 AM
Thanks John and Bruce. I imagined it was a steel rim under there. Just never wanted to destroy a wheel to find put for sure.
I plan to send this off to Dallas Steering Wheels. They did an awesome job on my ‘86 944 Turbo wheel. But they don’t paint so I’m going to have to get the metal portion of the 914 wheel repainted before I send my tenet wheel off to them. |
johnhora |
May 20 2021, 09:29 AM
mepstein |
May 20 2021, 09:53 AM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yea, don't pull off the foam. It makes a good base for leather.
Though you might want to trim back the foam on the spokes before you paint it. Otherwise the covered spoke part comes out a bit long. |
ClayPerrine |
May 20 2021, 11:27 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Thanks John and Bruce. I imagined it was a steel rim under there. Just never wanted to destroy a wheel to find put for sure. I plan to send this off to Dallas Steering Wheels. They did an awesome job on my ‘86 944 Turbo wheel. But they don’t paint so I’m going to have to get the metal portion of the 914 wheel repainted before I send my tenet wheel off to them. Dallas Steering Wheels did all of our 914s. Mine was thick padded, and you can't feel the finger dimples on it. The other two are just leather over the hard plastic. You can feel them in there. Clay |
76-914 |
May 20 2021, 03:41 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Yea, don't pull off the foam. It makes a good base for leather. Though you might want to trim back the foam on the spokes before you paint it. Otherwise the covered spoke part comes out a bit long. That's a great tip Mark. (IMG:style_emoticons/default/beerchug.gif) |
Rob-O |
May 20 2021, 09:51 PM
Thanks John and Bruce. I imagined it was a steel rim under there. Just never wanted to destroy a wheel to find put for sure. I plan to send this off to Dallas Steering Wheels. They did an awesome job on my ‘86 944 Turbo wheel. But they don’t paint so I’m going to have to get the metal portion of the 914 wheel repainted before I send my tenet wheel off to them. Dallas Steering Wheels did all of our 914s. Mine was thick padded, and you can't feel the finger dimples on it. The other two are just leather over the hard plastic. You can feel them in there. Clay Thanks Clay. I remember seeing the wheel in one car but not sure I saw the thick padding. Maybe I did and just don’t recall that. After having the stock wheel back on for over a year I have come to enjoy it. But it would be cool (to me) to have a thicker wheel and no finger dimples. It sounds like keeping the foam is the right thing to do so just getting some padding and leather should be enough. |
Rob-O |
May 20 2021, 09:55 PM
Yea, don't pull off the foam. It makes a good base for leather. Though you might want to trim back the foam on the spokes before you paint it. Otherwise the covered spoke part comes out a bit long. Mark do you mean trim the foam on the spokes back so that after painting the wheel and putting the horn pad back on there is room for the horn pad to move? I thought about what to do there. I was afraid that with the foam that if that just got covered with leather, the leather would then ‘end’ just a bit closer to the center of the wheel, potentially causing interference with the horn pad. |
Rob-O |
May 20 2021, 09:59 PM
Awesome, thank you for that!! (IMG:style_emoticons/default/biggrin.gif) Is this your wheel? I swear I’ve seen this picture before. Part of a post where the wheel was stripped so the dish could be made deeper? I may have to do a search and see how that was repadded. |
mepstein |
May 21 2021, 06:13 AM
Yea, don't pull off the foam. It makes a good base for leather. Though you might want to trim back the foam on the spokes before you paint it. Otherwise the covered spoke part comes out a bit long. Mark do you mean trim the foam on the spokes back so that after painting the wheel and putting the horn pad back on there is room for the horn pad to move? I thought about what to do there. I was afraid that with the foam that if that just got covered with leather, the leather would then ‘end’ just a bit closer to the center of the wheel, potentially causing interference with the horn pad. Yes. You can always talk with Dallas custom to confirm but I found the spokes will be a bit long unless you cut back the foam. Do it before you repaint. |
ValcoOscar |
May 21 2021, 06:55 AM
Garage Life Group: Members Posts: 2,480 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
Awesome, thank you for that!! (IMG:style_emoticons/default/biggrin.gif) Is this your wheel? I swear I’ve seen this picture before. Part of a post where the wheel was stripped so the dish could be made deeper? I may have to do a search and see how that was repadded. Is this the thread? http://www.914world.com/bbs2/index.php?sho...ering&st=40 Oscar |
Rob-O |
May 21 2021, 08:29 AM
@ValcoOscar that is the thread I was thinking about but I didn’t see that particular picture in your thread.
Lo-Fi Version | Time is now: 26th December 2024 - 09:41 PM |
