> L-jet to carb fuel pump wiring
jmargush
post Jun 10 2021, 02:13 PM
I am going to be initially running a newly rebuilt engine on carbs instead of the L-jet and need to get the fuel pump set up for that.
Can I use the stock wiring for the pump?
I think I need to have a work around since the AFM won't be installed.
Can anyone shed some light on a good way to accomplish this.
Replies(1 - 7)
ndfrigi
post Jun 10 2021, 03:39 PM
http://www.914world.com/bbs2/index.php?sho...54&hl=carb*
930cabman
post Jun 10 2021, 04:32 PM
+1, thanks to Andy. make sure your fuel supply is in the 3 - 4 psi range for carbs.
jmargush
post Jun 10 2021, 07:54 PM
Awesome,
thanks
jmargush
post Jun 11 2021, 04:54 AM
If you wire it as in Sir Andy's How To, does that keep the pump form running if the engine dies?
ejm
post Jun 11 2021, 05:43 AM
I can see the light at the end of the tunnel
The fuel pump how to thread works with cars that had D-jet. A separate relay was used with L-jet and those cars would need relays installed on the board.
The pump will run as long as the key is on.
bdstone914
post Jun 11 2021, 06:04 AM
bdstone914
QUOTE(ejm @ Jun 11 2021, 04:43 AM) *
@jmargush
Correct.
Add a relay into the socket second from the end of the board closest to the rear of the car.
jmargush
post Jul 13 2021, 01:23 PM
Is there an easy way to signal the pump to shut off if the engine dies while the key is on?
- Lo-Fi Version Time is now: 27th December 2024 - 08:49 AM
