Best Cam for 2056 and Dub Shop EFI? |
bkrantz |
Jul 14 2021, 08:11 PM
914 Guru Group: Members Posts: 8,175 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Since I had to tear down my partially built engine (to have the case decked), I have a second chance to choose a cam shaft. This build will be a 2056, target compression ratio of about 8.6:1, and the complete EFI and electronic ignition from the Dub Shop (based on Megasquirt 2).
Any wise suggestions? |
EdwardBlume |
Jul 14 2021, 10:59 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
9590 Raby / LN Engineering- $$$$
euro911 |
Jul 15 2021, 01:07 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I ran a Raby 9580 with 9.5:1 C/R and IDF-40 carbs ... not sure with MS EFI. Maybe consult with Jake or Len (IMG:style_emoticons/default/confused24.gif)
BeatNavy |
Jul 15 2021, 03:48 AM
Certified Professional Scapegoat Group: Members Posts: 2,944 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
The cam the type 4 store currently markets for being slightly more aggressive yet compatible with FI is the 9590. I've had one in a 2056 with D-Jet and now in my 2270 with microsquirt. It's excellent, with the possible exception that the first 30 seconds of a cold start require some throttle feathering. It really wants more air than the TB can give it when stone cold.
On the 2056 I was running 8.6 and the 2270 is 9.0. Same situation on each, although I think Jake said it really isn't designed for CR above 8.5 / 8.6. I've seen others say similar things, so it's likely not just me. |
914Sixer |
Jul 15 2021, 06:00 AM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Elgin 330-1 might work. Click to open
Attached thumbnail(s) |
ClayPerrine |
Jul 15 2021, 07:49 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The cam the type 4 store currently markets for being slightly more aggressive yet compatible with FI is the 9590. I've had one in a 2056 with D-Jet and now in my 2270 with microsquirt. It's excellent, with the possible exception that the first 30 seconds of a cold start require some throttle feathering. It really wants more air than the TB can give it when stone cold. On the 2056 I was running 8.6 and the 2270 is 9.0. Same situation on each, although I think Jake said it really isn't designed for CR above 8.5 / 8.6. I've seen others say similar things, so it's likely not just me. (IMG:style_emoticons/default/agree.gif) Put one of the Raby 9590 cam kits in Betty's motor. It ran great and pulled strong, but didn't want to idle dead cold. Feathering the throttle for the first minute always worked. Clay |
barefoot |
Jul 15 2021, 11:23 AM
Senior Member Group: Members Posts: 1,334 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I'm using WEB #494 cam & tappets with carbed 2056 at about 8.6 CR. Good low-mid range torque I usually ignore 1st gear unless an up-hill start. I'm happy with it
colingreene |
Jul 15 2021, 07:48 PM
Senior Member Group: Members Posts: 731 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Did you ask the dub shop?
Id go for 9.0 compression. If its the carb style throttle you can get away with a lot more cam. really with that efi you can put a pretty rowdy cam in it anyway. |
bkrantz |
Jul 15 2021, 10:15 PM
Thanks, everyone. I have twin IDF throttle bodies and (for now) stock 2.0 heads.
I have also asked Mario. |
djway |
Jul 15 2021, 11:28 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
The T4 in my notchback 78x96 9.0to1 has the Webcam 73 in it with the L Jet. It gets your attention.
JamesM |
Jul 16 2021, 08:53 AM
Advanced Member Group: Members Posts: 2,023 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
The nice thing about Megasquirt is one way or another it should be able to fuel whatever motor you want to build so the idea of a "best" cam is going to be relative to personal preference and the rest of your engine build.
My personal preference MORE!!! More cam, more compression, more headflow etc. Among other things I have put megasquirt on both a 2270 with ITBs and a torquey cam that was done making power by ~5500 and a 2056 with higher compression, a hotter cam, and better flowing heads on a 1.8 plenum that didnt even come on cam until around 3800 rpm and I think the 2056 is WAY more fun to drive. But you have to wind it out to get the most out of it and that isnt for everyone Since I had to tear down my partially built engine (to have the case decked), I have a second chance to choose a cam shaft. This build will be a 2056, target compression ratio of about 8.6:1, and the complete EFI and electronic ignition from the Dub Shop (based on Megasquirt 2). Any wise suggestions? |
bkrantz |
Jul 16 2021, 07:53 PM
At the risk of blowing this discussion wide open, what about heads and valves? While I am dreaming of options, what about after-market heads? Bigger valves?
FWIW I wish for a motor that is mostly easy to live with, and with a bit more go than stock. To hazard a number, something like 120 hp. |
djway |
Jul 16 2021, 08:14 PM
At the risk of blowing this discussion wide open, what about heads and valves? While I am dreaming of options, what about after-market heads? Bigger valves? FWIW I wish for a motor that is mostly easy to live with, and with a bit more go than stock. To hazard a number, something like 120 hp. I went with 44x38 stainless valves. |
Lo-Fi Version | Time is now: 26th December 2024 - 05:30 PM |
