Windshield Washer Switch Question |
GeorgeKopf |
Jul 18 2021, 12:39 AM
Member Group: Members Posts: 189 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
On my wiper switch there are 5 wires. Black, Brown, Green, Black/White, Black/Green
The black wire (behind the brown) mates to a brown/black wire on the main harness which isn't used. It was capped off and taped into the body of the harness right at the wiper motor. My wiring harness is a 1973. Testing for continuity between the black and the ground I get tone when I pull the wiper switch forward. I also get continuity on the black/white wire which connects to a red/black wire to the wiper motor. Can I use the black/brown to power an electric washer pump? Thanks. George |
914Sixer |
Jul 18 2021, 06:16 AM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
What you are describing is the circuit for the intermittent wiper. IF you break the tab off on stalk, the all the way down position is a hot circuit. You would have to move switch back up to neutral to turn off washer pump. You need a 6 wire switch if you want washer and intermittent wipers.
GeorgeKopf |
Jul 18 2021, 02:48 PM
Thank you Sixer.
I've been researching and reading and it looks like if I get a 6 pole wiper switch, I will need to run a wire from the switch to the washer pump. Since my wiring harness is out of the car, now would be the time. I'm assuming a few things: 1. I can share the wiper motor's ground wire for the washer pump. 2. I can run the wire directly (without going through the fuse box) 3. I will need an intermittent harness (and relay). Please let me know if I've got that right. Thanks. George |
914Sixer |
Jul 18 2021, 03:31 PM
Your correct. Check out intermittent wiper installation in the Classic section.
SirAndy |
Jul 18 2021, 03:42 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can I use the black/brown to power an electric washer pump? Yes, you can: http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/shades.gif) |
GeorgeKopf |
Jul 18 2021, 09:58 PM
GeorgeKopf |
Jul 18 2021, 10:00 PM
Can I use the black/brown to power an electric washer pump? Yes, you can: http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/shades.gif) Thank you Sir Andy. I read that post and will definitely be referring back to it when the time comes. George |
Lo-Fi Version | Time is now: 27th December 2024 - 08:15 AM |
