Master Cylinder removal, the top lines |
EJP914 |
Jul 18 2021, 09:12 PM
Member Group: Members Posts: 267 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
I have disconnected all of the fittings at the MC, removed the switch, removed the 2 13 mm nuts, and disconnected the lines at the brake fluid reservoir. My problem is the rubber fittings and steel (?) lines at the top. That looks to be what wont allow the MC to pull out.
How do these come out? I was going to try to pry them out with a screwdriver but thought they would get destroyed. Thought about grabbing the steel line with channel locks and try to wiggle them out. I have a new MC coming from PMB but don't know if comes with new rubber fittings? Are they usually supplied with new MC's? I would vey much appreciate the advice and guidance. Thanks EJP914 |
bdstone914 |
Jul 18 2021, 09:40 PM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Yes new naster cylinders have new grometts. Twist and pull. Remove the reservoir strap to get some slack on tbe lines
Mikey914 |
Jul 18 2021, 10:30 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Don’t forget the washers
pneuhyde |
Jul 18 2021, 10:33 PM
Member Group: Members Posts: 102 Joined: 24-February 05 From: San Leandro, Ca. Member No.: 3,654 Region Association: Pacific Northwest |
I have disconnected all of the fittings at the MC, removed the switch, removed the 2 13 mm nuts, and disconnected the lines at the brake fluid reservoir. My problem is the rubber fittings and steel (?) lines at the top. That looks to be what wont allow the MC to pull out. How do these come out? I was going to try to pry them out with a screwdriver but thought they would get destroyed. Thought about grabbing the steel line with channel locks and try to wiggle them out. I have a new MC coming from PMB but don't know if comes with new rubber fittings? Are they usually supplied with new MC's? I would vey much appreciate the advice and guidance. Thanks EJP914 Just a remark about the general work involved. After much struggling in too tight of a space, I found it much easier after I went ahead and loosened up the torsion bar? holders and swung it down out of the way. Steve |
Lo-Fi Version | Time is now: 27th December 2024 - 11:29 AM |
