Recommendations for plug wires…, Bad Beru wire with only 1000 miles on it! |
pnewman |
Sep 14 2021, 10:07 PM
Member Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
So one of my Beru wires went bad with only 1000 miles on it, = not happy camper
Looking for recommendations and sources. 2.0 liter (short ends) Was talking to LN Engineering about Magnecor 8mm # 40442 $96.05 https://lnengineering.com/products/magnecor...n-wire-set.html Thoughts If Magnecor then what size? Thought 8mm just fine for my set up. (For my 2056 w/ L-Jet) Thoughts and sources? (Thanks in advance, Pete) |
steuspeed |
Sep 15 2021, 12:34 AM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Just went through my ignition with new plugs and wires. Car has Pertronix and was running and sputtering. Went with standard NGK plugs since they were fouling. Stepped up for Clewett Engineering wires. Didn't fix it. Incorrect MPS was the problem. The car runs better than ever now. The bad thing about larger diameter plug wires, is none of the wires will fit in the clips now. I saw zero change from my old crap wires to the spendy Clewett. Think I would go with a NGK wire set next time.
pnewman |
Sep 24 2021, 08:34 AM
Update:
I ended up going with : Magnecor Electrosports 70 SS Ignition Wire Set including coil wire, 7mm (black)(1974 Porsche 914 4-cyl T Part #: PEL-MAGN47442 https://www.pelicanparts.com/More_Info/PELM...n=PEL-MAGN47442 Via pelican parts. $101 with Free delivery. (Sept 2021) I received them in under 5 business days drop shipped from their supplier. They are 7mm which allows the utilization of the oem wire holders. The wires have 90 degree bends a the cap which I like but they are a bit long. I am guessing that they kept them the same length as oem but the 90 terminals shorten the needed length. Oh well, Better too long than 1mm too short. They run just as good as the $30 Beru's did. I spent the money on the Magnecors in the hope that they last longer than 1 year! I hope that this helps anyone searching in the future. |
VaccaRabite |
Sep 24 2021, 11:04 AM
En Garde! Group: Admin Posts: 13,554 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
With the Magnecors - be careful. They are ~1mm thicker then the stock wires, and the lead holders can score the insulation if you aren't careful.
Zach |
pnewman |
Sep 25 2021, 10:01 AM
With the Magnecors - be careful. They are ~1mm thicker then the stock wires, and the lead holders can score the insulation if you aren't careful. Zach Zach, Magnecor offers 7mm/8mm/8.5mm Wires for our 914’s currently. The wires that I bought from Pelican (see post above) were 7mm. They fit perfectly in the oem wire holders without anymore compression than the Beru wires and Magnecor provided wire organizers as well. Hope this helps anyone shopping for wires. FYI only time will tell if they last. Pete |
Lo-Fi Version | Time is now: 28th September 2024 - 09:20 PM |
