RangerDick |
Newbie ![]() Group: Members Posts: 18 Joined: 15-May 17 From: Burlingame, CA Member No.: 21,104 Region Association: Northern California ![]() |
Planning on pulling the engine to refresh the tins, hoses and gaskets. I noticed the intake runners are pretty trashed. Anyone know the gray color that is used to paint them?
Thanks in advance |
Maltese Falcon |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,727 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
[quote name='RangerDick' date='Sep 19 2021, 06:37 PM' post='2946801']
Planning on pulling the engine to refresh the tins, hoses and gaskets. I noticed the intake runners are pretty trashed. Anyone know the gray color that is used to paint them? Thanks in advance [/quote Can't go wrong with putty-grey...about the same color as most of the new 911s rolling off the showrooms (IMG:style_emoticons/default/biggrin.gif) |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Same color as the headlight carrier metal. Got you covered -
https://914rubber.com/headlight-carrier-satin-grey-paint Attached thumbnail(s) ![]() ![]() |
Aerostatwv |
Member ![]() ![]() Group: Members Posts: 118 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region ![]() ![]() |
Here’s a good match if you need high temp:
https://www.stoddard.com/nla09500600.html Covers extremely well. Chris |
branston |
Member ![]() ![]() Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest ![]() |
I've been restoring VW intakes for years and found the closest and most reasonable priced paint is Duplicolor's New Ford Grey engine enamel with ceramic, its a little glossier than the original satin, but dulls a little once its been on the engine. Perfect color match and Autozone carries it.
https://www.duplicolor.com/product/engine-e...l-with-ceramic/ |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Paint them red. Everyone knows that red is the fastest color. (IMG:style_emoticons/default/driving.gif)
RangerDick |
Thank you All!!!! Now I'm troubled by all the choices. HaHa. Really appreciate the quick responses.
Lo-Fi Version | Time is now: 25th June 2024 - 11:56 PM |
