Rick986 |
0-60 in 14 seconds! ![]() ![]() Group: Members Posts: 141 Joined: 31-August 21 From: NE Ohio Member No.: 25,869 Region Association: Upper MidWest ![]() ![]() |
Does anybody have pix of the correct factory install of the canister on an original '75 1.8L? Thanks!
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Does anybody have pix of the correct factory install of the canister on an original '75 1.8L? Thanks! Check the originality forum http://www.914world.com/bbs2/index.php?showtopic=108524P |
rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
I have been using the battery hold down bolt to keep the Canister in place on my 75 1.8.
Sure would like to know where its mount for sure though... |
Steve |
I have been using the battery hold down bolt to keep the Canister in place on my 75 1.8. Sure would like to know where its mount for sure though... Not factory, but I mounted mine between the battery and the firewall, to get it out of the way. However my car is a six and i do not have the 4 banger ECU there. |
bretth |
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region ![]() |
I have seen it on the firewall and on the battery tray for the 1975 1.8. I would like to know which was correct myself. I could see the firewall mount used because the L-jet dual relay looks like it should be on the battery tray and my car has a hole in the firewall area. But then there are a few other non original holes on my firewall too.
drem914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,034 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 07:28 AM |
