914 Rubber (Late) Hood springs hood sag issue |
L-Jet914 |
Sep 26 2021, 09:54 PM
Member Group: Members Posts: 265 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I recently purchased a set of 914Rubber Late hood springs for my 74 914 back in May and received them in June. The install went without a hitch and I put them on the second notch where my old ones were. The day of the install the new springs held up my hood with no issues. I went out to the garage today to open the hood and now the hood springs no longer hold the hood all the way up. The hood sags to where it used to when I had the original hood springs installed on the same notch. I will move the hooks up to the 3rd notch to see how it goes, but I was curious if anyone else have had this issue with their new 914Rubber hood springs? I figured a new hood spring tension would allow me to go to the first notch, but I ended up on the second notch during the install. Thank you in advance.
Dredwin |
Sep 27 2021, 10:51 AM
Member Group: Members Posts: 71 Joined: 21-December 13 From: Colorado Springs Member No.: 16,783 Region Association: Rocky Mountains |
I read somewhere the earlier model springs were shorter so I ordered those. I moved so I didn't have a chance to install them but that is what I read some folks were doing.
I recently purchased a set of 914Rubber Late hood springs for my 74 914 back in May and received them in June. The install went without a hitch and I put them on the second notch where my old ones were. The day of the install the new springs held up my hood with no issues. I went out to the garage today to open the hood and now the hood springs no longer hold the hood all the way up. The hood sags to where it used to when I had the original hood springs installed on the same notch. I will move the hooks up to the 3rd notch to see how it goes, but I was curious if anyone else have had this issue with their new 914Rubber hood springs? I figured a new hood spring tension would allow me to go to the first notch, but I ended up on the second notch during the install. Thank you in advance. |
Mikey914 |
Sep 27 2021, 11:14 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
1st issue I've heard of. These are oil tempered springs so there shouldn't be much variation in this short of time.
Again, we stand behind our products and as we mentioned in your relay issue ( that our relay was allowing more current through that was popping your fuse, we will accept returns for ANY reason. It's just usually easier if you contact us. |
Ansbacher |
Sep 27 2021, 02:57 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
If you are not too anal about considering something non-stock, the CAMP914 Hood Shock Kit is the way to go. No messing with those dangerous springs, no hood flutter on windy days, and no head bumping due to hood sag.
Ansbacher |
Lo-Fi Version | Time is now: 20th September 2024 - 04:55 PM |
