Rear trunk lid torsion bar installation |
partwerks |
Oct 1 2021, 07:12 PM
Senior Member Group: Members Posts: 1,599 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
My mechanic forgot to put the rear trunk lid torsion bars in before installing the engine.
There is clearance that runs along the back side with this setup. If I remember correctly, Renegade told me they would fit with no clearance issues. Anyway, the thing I'm wondering if I will be able to put them in after the fact?? What is the technique in putting them in? |
914Mels |
Oct 1 2021, 08:51 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
914Mels |
Oct 1 2021, 08:55 PM
partwerks |
Oct 1 2021, 09:33 PM
914Mels |
Oct 1 2021, 09:43 PM
Not really, once you get them in the engine compartment and thru the loop, it's more finding room to push the bar down to get it on the roller. the factory tool is a specialty tool but I believe I was able to put a deep 10mm socket over the end of the bar and with an extension, push down enough to get it on the roller.
914e |
Oct 1 2021, 10:32 PM
Member Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
914 rubber sells a tool.
Arno914 |
Oct 2 2021, 01:01 AM
Member Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany |
There is enomous tension on those springs. DonĀ“t attempt to mount them with a 10mm socket or the like. Get the correct tool. Is way cheaper than a hacked off finger (and an easy job, too!). (IMG:style_emoticons/default/w00t.gif)
You eventually need it in the future anyways to take tension off the rollers for lubricating or changing them. |
euro911 |
Oct 2 2021, 07:23 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
rgalla9146 |
Oct 2 2021, 06:23 PM
Advanced Member Group: Members Posts: 4,673 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Putting the rollers under tension is a known issue.
The OP is asking if it is possible to install the torsion bars in position through the loop on the back wall of the engine compartment. I don't know if it can be done with a standard 4cyl or 6cyl engine. Anyone ? With a small block ? could be easier or harder..... I'd start by putting the short arm of each bar through the center loop and feed it toward the opposite side of the car. Give it a try. See what happens |
partwerks |
Oct 2 2021, 07:29 PM
Lo-Fi Version | Time is now: 5th January 2025 - 07:45 AM |
